Tow truck...can s10 handle it?
Discussion in 'The Garage' started by BigBurban350, May 2, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Do you think an S-10 4.3 litre can haul a K-5 with a car dolly without putting excessive strain on it? They are cheap and get better gas mileage then a fullsive. Thanks. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    I honestly wouldn't do it. It can, but that truck won't last long pulling a load like that. Besides, it just isn't as safe.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Agreed
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    can it move it? Yeah. Can it move it at freeway speeds? I wouldnt. In some silly ways, I think its safer to flat tow it.
  7. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    I have an 87 S-10 and I would have to say NO! I don't think there would be any way for an S-10 to stop with a fullsize anything in tow.
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I have towed my K5 with my '01 Blazer(2WD, 4dr, 4.3 Vortec) across town and it did fine. I kept the speed below 30mph and I would NOT recommend trying to get on the highway with the setup. It's works for emergencies but I would not try to save money by trying to make an S-10 a tow rig...
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    IF you had a drivetrain that COULD handle the load, the frame of the s-10 would crumble like a frenchmen on the front lines under the weight of the K5.
  10. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    I have a 98 S-10 with a vortec 4.3. Its regular cab short bed with and a standard. I use to pull a 21 foot kenner bay boat with a 200 mercury with no trouble. 5th gear at about 60 on flat highways. I wouldnt go with anything heavier than that boat but I dont know what it weighs. I would think not on a one ton K5 but maybe a stock. This truck also has 100K miles on it and the only thing thats been replaced is the belt and tires. I also guaranty you that is the worst 100K miles a 2wd s-10 has seen. Best truck I have ever owned and I love smoking decked out cromed up fullsizes off the line with it. Itll burn third nicely. The fact that this truck is white and has not been washed in over 3 years makes that even more humiliating. Put all that together for a 24 MPG vehicle at the price they come and its a damn good package. Spend about $700 to that engine on programmer, exhaust, intake it will really come alive.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif ROTFLMFAO!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've had to do a panic stop in my '91 S-Jimmy at freeway speed, while towing just a mini-truck-bed-converted-to-a-trailer, "loaded" down with a 14-bolt FF and a 10-bolt. It was scary as hell!!! The 4.3 can get a lot of weight moving, but that tiny-a$$ truck can NOT stop a heavy load. /forums/images/graemlins/eek.gif
    If you want to tow heavy loads, you need something designed to do that job. An S-10 does NOT fall into that category. /forums/images/graemlins/frown.gif If you want good mileage in a tow vehicle, start looking at turbo diesel powered fullsize trucks. /forums/images/graemlins/thumb.gif
  13. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    shouldn't be a problem. In fact, the 4 cylinder engines get even better gas mileage. Why dont you go for one of those? And get a fullsize trailer to pull your K5. Yeah, then you'll have the best of both worlds. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  14. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    If there was a lake with 1/2" of ice on it... and you REALLY needed to get to the other side and just decided you didn't want to go around the dang thing... would you just get a running start and see if you could make it? /forums/images/graemlins/eek.gif
    Somewhere in there is the motto to this entire thread... hrmm....
    -Dan
  15. Grim-Reaper
    7,385
    Atlanta
    Hell no!
    I just dragged my 79 110 miles on a car trailer with a 454 burb and I felt every bit of that 7500lb.
  16. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Kinda like 1 day old crusty french bread... /forums/images/graemlins/rotfl.gif
  17. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Aight, I get the point! Thanks for the feed back though /forums/images/graemlins/rolleyes.gif.
  18. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    No. Even if the engine can get it going...can the brakes handle stopping it? I doubt it.
