towing 2tons with 1/2 ton brakes
Discussion in 'Tow & Trailer' started by tecton, Apr 30, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    what a bad idea
    never towed anything that big with my k5 and then out of the blue, opportunity for $ knocks....so i tow a 2ton trailer loaded with construction scrap about 50 miles highway
    the brakes were almost totally useless...i had to downshift all the way to first and then brake about 5 times farther than i normally do
    i dont know too much about towing so excuse my newbiness...just wanted to comment
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Larger tires+ stock brakes= already reduced braking power. (Larger tires add more leverage, and diminish brake power).
    4000+ scrap, Its ok. But did your trailer have brakes? If not, your seriously stressing out the brakes. I did 3500 unbraked, and blued my rotors from the heat.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You should not be towing more than 2,000 lbs without brakes, and even that is pushing it.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    what a bad idea
    I have done worse when I had to tow a suburban 3/4 ton 4wd on a 7k lbs trailer and my 1/2 truck didn't have a brake controler, but at the same time I didn't go over 45MPH on Highway and 25-35 mph o surface streets.
    It wasn't the easiest drive but it worked fine and didn't have any close calls or faded my brakes.
    Always go slow when towing, and slower when towing with no brakes.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    This weekend I'll be towing a 4,500 lb. K5 on a no-brake trailer with 4 wheel manual drums. /forums/images/graemlins/yikes.gif Good thing the truck isn't even capable of going over 40, and it's a 3/4 ton longbed. /forums/images/graemlins/waytogo.gif
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    One thing I also forgot to mention, I only towed it for 12 miles, not accross country. /forums/images/graemlins/yikes.gif
