Towing capacity
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scavenger, Aug 31, 2000.
  1. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    Hi. I have an 85 full size Blazer that is pretty much stock and I am curious if any other board member uses their K5 to pull a trailer with a skid loader (Bobcat). I am considering purchasing a skid loader and trailer to pick up some extra $$$ doing odd jobs and general dirt pushing. The skid loaders weigh between 5500-6200 pounds and it seems to me that this with the added weight of a trailer may be too much for the K5 to handle. Eventually I plan to get a 1 ton dump but was just wondering if the Blazer could handle it until that time......thanks
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    No problem I have a 1984 K5 with a 2.5 inch lift, 33's, stock 350,and stock gearing. My dad tows a double axle horse trailer,and 2 big horses....never had a problem! The only thing is freeway speed,and going up steep hills! hope this helps..
  3. scavenger
    Mar 31, 2000
    111
    Southern Wisconsin
    Thanks for the info Eric.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Make sure you tow in Drive, not Overdrive, and install a tranny cooler, too.
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I tow a 21 foot travel trailer with my Jimmy. It weighs in at about 5300 lbs with all our junk. I pull mine at about 70 MPH with not too much trouble. Quick specs on my Jimmy: Warmed over 350 comp cams 260 HE, Edelbrock 600, Accel super coil, Flo-tech headers, 2 1/2" duals with Flowmasters. 4 speed manual tranny, 3.73's and 35" mudders. If the skidder is betwen 5500 and 6200 lbs, how much does the empty trailer weigh? I know an average car trailer comes in at about 2100 lbs. This would make the total loaded trailer weight at over 8000 lbs. Just for comparison a 35' fifth wheel trailer (the monster ones) weigh less than this! I personally know what 5300 lbs behind my truck feels like and what a bitch it can be to slow it down, even with good electric brakes, I don't know how comfortable I would be with 8000 lbs behind me.
    You also have to consider the hills. Where I tow my trailer there are several hills in the 7 to 10 % area that can be quite long. If you have an automatic then it will be a little easier to maintain the power up the hills but I would be pretty worried about the heat generated. I know that with my set-up I'm in 3rd gear at 2500-2800 RPM and the gas about 1/3 to 1/2 way down on the big hills, obviously the steeper the hill the more pedal I use.
    IMHO I would wait for the 1 Ton, but if you are going to try the K5 then make sure you have a good weight distributing hitch and that the trailer has very good brakes.
    Just my 2 cents
  6. scavenger
    Mar 31, 2000
    111
    Southern Wisconsin
    RustyK5,
    Thanks for posting the info. I was really hoping to use the Blazer for a while until I found something a little larger, but you do state some real good reasons for not using it. I thought I lucked out yesterday when a person offered to give me a Chevy medium duty 5 yard dump truck. After explaining the condition of the truck to some friends that work on trucks they advised me to let the "bargain" go. I was told that since the truck has been sitting for 6 years and is a diesel, that I would probably have to invest 2-3 grand in the motor before I even attempted to start it. And also because it has been sitting so long the air brake system is probably shot along with several other items. If it were a gas engine I would probably tinker with it, but I know nothing about diesels so I guess I'll just keep looking..........Thanks
  7. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I would not put any stress on that 700R4 if it is an '85 model trans. Just my experience after 3 rebuilds. Due to towing weight, I converted to a 5 speed stick. With 4:88s, Dana 60FF, 35s and the NV4500 I have been pulling a lot of weight w/ no problems except shortened life on the 1/2T Ujoints. I now have changed to the 1350 UJs, weigh
    15,000+ GCVW occasionally and do OK. I have 12" brakes front and rear on the K5, and oversize brakes on
    the trailer (Dexter 12x2 shoes, twin axle) My K5 weighs 6200 lbs. with me in it on the scales.
    SteveB
