Towing compacity of 1/2 vs 3/4 ton
Discussion in 'The Garage' started by MuddNutz, Sep 14, 2004.
  1. MuddNutz
    MuddNutz Registered Member
    Nov 3, 2002
    61
    I am looking for a 80's model 4x4 and I want a 3/4 or 1 ton so that I can pull a heavy trailer every once in a while but they are hard to come by. I have been looking at 3/4 tons with 350 engines and th400 transmissions, and I was wondering if I got a 1/2 ton with a 350 and th350 or th400 and swapped in 3/4 ton axles into it then beefed up the rear suspension would it tow as well as the 3/4 ton? What else is different between the 1/2 and 3/4 tons?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    1/2 and 3/4 tons use the same frame, so beef up the suspension, put a th400 in an go.
    Dan
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    IIRC, 3/4 tons have different frames than a 1/2 ton.
    You could swap in all the 3/4 parts into a 1/2 but since you are looking for a truck wouldn't it be easier and probably cheaper just to buy a 3/4? /forums/images/graemlins/screwy.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    As long as it's a longbox I don't see it as a problem.
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    1 tons are the only ones that have different frames. My 78 3/4 ton even uses 52" springs. The frame is identicle to my buddies 1/2 longbed.
    Dan
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my 83 k10 longbed and 83 k20 longbed have exactly the same frame.
  7. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ]I guess I stand corrected
  8. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    not sure if it holds true on pickups or not, /forums/images/graemlins/confused.gifbut on the suburbans (with no such thing as a 1 ton).. the frames APPEAR the same, but there ARE some differences. /forums/images/graemlins/shame.gif Thickness & metal strengths being the 'hidden' ones you normally don't catch with the naked (or clothed?) eye! /forums/images/graemlins/deal.gif (Confirmed in gm literature)
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    main things that affect towing are wheelbase (longer is better), suspension, gears, motor, and tranny. With the proper hitch it is quite reasonable to tow 8k lbs or more with a half ton 350sbc, sm465/th400, 1/2 ton axles with 4.10 gears. Be sure to run a tranny cooler if it's auto. And use a weight dist hitch.
  10. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I have towed and ridden in many 1/2 ton GM trucks,I think the towing capacity isnt that much of an issue,if you have a 12 bolt instead of a 10 bolt its better,as long as you have beefy springs and good tires(6,8,or 10 ply 16's are much better than 15" for heavy loads)and a weight distributing hitch they tow just fine--we towed many fullsize trucks and race cars all over with few problems--the biggest one is stopping in a hurry--I would not tow a trailer that doesnt have brakes,or not have them working correctly--more than once in a panic stop situation,we ended up being pushed sideways by the trailer,nearly jack knifed across the road--not that a 3/4 or one ton wont do the same,but the extra weight sure helps keep the rear axle on the ground!.A half ton truck is too light in the rear sometimes,we used to make sure we put the load on the trailer as far foreward as possible for more tounge weight to help keep it planted on the road.A bigger truck is always better for towing,but if you are careful,you can haul a lot with a half ton--its the sudden stops,and the fact that if an axle breaks your wheels fall off are the main drawbacks.I see a local contractor hauling 2 bobcats around town with a C10 diesel pickup quite often,and those things are heavy!. /forums/images/graemlins/crazy.gif
  11. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ]Thats what I was thinking....3/4 frames were slightly thicker than 1/2's and 1 tons were thicker along with being 3" taller. /forums/images/graemlins/screwy.gif
  12. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I think GMC's had thicker frames than most chevy trucks--My 74 GMC K20 is actually on a 77 GMC 1/2 ton K10 frame,comparing that frame to my 79 C10 2wd,the C10 looks much thinner gauge than the 77 4x4 one,although dimensionwise they are identical--maybe the 4x4's are thicker as a rule than a 2wd??.At any rate,I hav had many tons over the rated GVW on my truck,even with all the rust and rot,still had no problems--GM trucks have pretty beefy frames,even on K5's and 1/2 tons. /forums/images/graemlins/crazy.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They're the same.
    Bend one and then come back and tell me that.
    Honestly I think the crappy frames are one of the biggest shortcomings on these trucks.
  14. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I havent bent mine yet,not that I havent tried!--of course I dont do any off-roading to speak of,and perhaps the flatbed made of 4 inch channel iron helps "bridge"the frame and make it stonger,but I cant really say the GM frames are weak--not when I look at 90's ford 4x4's on my friends lift at his shop,and see how badly rotted they are already--and they have huge holes hole sawed in them,right where the cab and bed meet(the part that bends the most)--its beyond me how they live at all!.I think the newer GM trucks (88-up) have much wimpier frames than the old rigs--at least they dont look as rugged,maybe they are different steel,but the thickness and how rusty they already are doesnt impress me much--. /forums/images/graemlins/crazy.gif
  15. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    103
    Murphy, tx
    I don't know the answer, but...
    Do the 3/4 tons have bigger brakes than the 1/2 tons?
  16. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Yes they have larger brakes. The calipers in the front are the same, but the rotors are bigger. The rear drums are much larger and wider.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The calipers are not the same. Trucks with 13" rear brakes get bigger calipers even on a 10 bolt or Dana 44 front axle. The piston is mildly larger. As you stated, the rotors are larger as well, and the brakes on a 3/4 ton rear are bigger than a 1/2 ton but not as big as the 1 ton.
  18. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Yes, and you will notice a big difference in brake performance if you swap in a 3/4 14BFF with 2.5" drums. Mine work excellent and slow down me and my trailer loaded considerably quicker than when I was still 1/2.
  19. jwduke
    Aug 25, 2001
    721
    Wrong again Tim, they use the same part numbers. The difference is the D44 calipers & the 10 bolt calipers. The D44 calipers have a slightly larger piston.
    And as far as the rear drums, the 13" drums were offered on 3/4 tons with 10,000 + GVW., so some 3/4 tons do have 1 ton brakes (Rear)
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Open up a brake book if you do not believe me.
    There are FOUR different part numbers for front calipers on these trucks. Two for D44s, and two for 10 bolts. There are two differently sized pistons for both axle.
    Check your information before you run your mouth. You're pretty out of line trying to tell me something about auto parts unless it was blatently incorrect.
    Brake system detirmines which calipers you get. The bigger calipers also use different brake pads.
