towing device
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NYC K5, Apr 21, 2000.
  1. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    i have the original window sticker for my rig and it says it came with a towing device, but i dont have a hitch, and cant seem to find any wiring harnesses back there. what in the heck is it?
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I'm sure it did have a hitch at one point in time or another. They are very easy to remove. That along with lower gears, & larger fuel tank.
    Do you have a 31gal tank? How about 3.42:1 gears?
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  3. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    Mine must have had the same thing. I have a 31 gallon tank, and I seem to have fairly low gears. I don't have a tach, but the engine is reving pretty good at 75 mph. Is there a way to tell the gear ratio WITHOUT taking the cover off and counting teeth?
    Blazin' in Flagstaff
  4. NYC K5
    Apr 3, 2000
    185
    its definitely not lower gears because i have a 2.73 rear. i do have the sm465 4speed though and that will pull a house down. i also have the 25 gal tank, oh well reciever hitches are $100
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Don't ya mean a 3.73 rearend? I thought 3.08 was the highest gear put in the K5 series...
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  6. mico85K5
    mico85K5 Registered Member
    46
    Wheat Ridge, Colorado
    what does the 3.08 gear ratio actually mean (how good/bad is it?)
    Driving your blazer=FUN!
  7. NYC K5
    Apr 3, 2000
    185
    no its definitly 2.73 it says it on 2 forms that i have the window sticker and the glove box info thing, plus the car had no pickup before my mods
  8. Truckfan3
    Truckfan3 Registered Member
    Apr 22, 2000
    6
    Northern IL
    the higher the number or gear ratio, the lower the gear... if that makes sense. anyway, it all depends on what size tyres and what kind of driving you do and what you want the gas mileage to be. usually, the lower the ratio, the more torque and power you have at take off but your engine will be reving higher at fast speeds and the mpg will drop. the lower the ratio, the slower to get going but faster you will go, mpg is good on the highway but lacks during stop and go. overall, it only matters for person to person. some will like get up and go (low gear ratio) and others don't care. it also matters with the size tyres, the bigger the lower the ratio you need to get the rpm back to where it was stock with small tyres. hope I helped!
    If it isn't broke, then modify it!!
  9. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I wonder if they call the large fang looking hooks under the front bumper a towing device?
