towing gurus......? 4 you..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, Oct 20, 2001.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i just bought a 1976 Dodge class c rv (360, 727, big @ss rearend, dual wheels etc) and am wondering if it will tow me Jimmy on a car trailer. the "book" says not to "...tow more than 75% of the vehicles weight." will i be alright??
    thanks rob
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    For the Jimmy it should be fine - those old RV's will tow a bunch[​IMG]
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Figure your K5 &amp; trailer together weigh about 7500# (6000 + 1500) minimum, your motorhome is going to weigh about 11500 - 12500#, you'll have about 19,000# for the 360 to move around. Pretty good load but can be done. 75% of 12,000 is going to be 9000, so you're within range. Transmission is going to be worked pretty hard, especially in hilly country. Check and make sure you have the biggest trans cooler you can get, usually about 24,000GVW.
    A good firm grip is my idea of gun control!
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    And have someone make sure the bands are adjusted right in the 727.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    also don't forget your wallet, you will need it alot to pay for the incrediable amount of fuel it will consume.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/chevyracing>http://community.webshots.com/user/chevyracing</a>
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    It should do fine. It will, however, pass nothing, including gas stations. Make sure that the engine is in good tune, fresh oil, coolant etc. I'll second a big tranny cooler too.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  7. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    the engine and tranny have been overhauled about 30,000 miles ago, and i have read up on the band adjustment, and others around here have mentioned the importance, which is cool, because i know little or nothing about MOPARS!! it has a somewhat big tranny cooler on it now, but it will not be big enough. They arent that much anyways.
    thanks for all the input...rob
  8. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Rob.... a couple more things to consider.... how long is this motorhome ? i know it is a class C, and what will the terrain be like that you will be towing accross ? You will be working the 360 pretty hard, if you had the MH's with a 440 you would have much better luck.
    1990 K5 4" lift, 33's, Raptor Tranny and Velvet Rides....
  9. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    hmmmm....i am thinking its 24 foot. def. more than 20.
    i will be towing over some hills, but nothing too extreme or long, i know those LONG climbs are extremely hard on parts, esp. when towing 6000+ lbs. one thing i need to do is get my truck weighed so i know for sure.
    no kidding on the 440!! i wish [​IMG]
    thanks rob
