Towing in Low?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JeremyK5, Oct 24, 2001.
  1. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    Tomorrow I'm going to be towing a heavy straw wagon at low speeds (25-30mph), and I need to know if it would be ok to use 4 low on my np203, so that I can accelerate with traffic. Thanks for any Info!
  2. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    The only time I know of anyone towing in low... A friend of mine in his Suburban on his way to top truck when he was going through the mountians. He did fine, just keep the speeds down.
    Ken H.
    '85 K5 in process
  3. Grim-Reaper
    7,385
    Atlanta
    Depending on your diff gears you can go as fast as 40mph in low range if you got 3.08.
    Now is the truck converted or still full time? If it's full then yeah low is fine just don't go to loc or you will get driveline bind and bust something. take it easy on the starts. let the truck pull it up easy if your talking some serious weight. I guess I don't have to warn you about trying to stop that weigh [​IMG]
    Women dig dents and flat paint!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Is it bad for stuff? Of course. Have I done it? Plenty of times.
    BTW, Grim, w/39.5s, 4.65s, and OD, you can get about 65 mph out of low. And thats with a 2.6:1 t-case. Plus LOTs of planetary noise. [​IMG]
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
