towing my blazer 1000 miles, need advice
Discussion in 'The Garage' started by 75K5, Mar 24, 2004.
  1. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    I am moving to florida, and I really don't want to drive my blazer the 1000 miles. My plan was to rent a large truck (25' uhaul or similar) and a car trailer. The problem is that all of the car trailers only support a vehicle weight of 4000lbs.
    Has anyone dealt with this before? My K5 is a 75 with full time 4WD.
    Thanks,
    Brian
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Are you renting the U-haul just to tow the K5? Or is it for moving your other crap too? If it's just for your K5, I would look into a transport service, because the rental fees on the Uhaul are gonna be outrageous! /forums/images/graemlins/eek.gif
  3. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    We are moving to florida, so the plan was to fill the uhaul up with all of our stuff. I looked at transporting it, but that's $1000, and I already have to pay $1000 for the uhaul, so if I could find some way to tow it I can save a thousand bucks.
    Brian
  4. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Check around with other U-haul places, I rented one to tow my Tahoe when I moved.
  5. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    That's what I figured. /forums/images/graemlins/waytogo.gif I've seen people putting heavier vehicles on their trailers. Not sure how safe that is or long they were towing them, but it has been done... /forums/images/graemlins/grin.gif
  6. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    yea, when I checked with them they said my 99 explorer was okay to tow, but the blazer wasn't. They are about the same wheelbase, and I can't imagine the blazer being that much heavier than the explorer. I may end up just doing it with a little more weight and driving slow, but I wanted to see if anyone else had any experiences with this before I take any risks. I can pull the back seats out and get some weight out of it, but I doubt it's near 4000lbs. The nearest weight station is about 50 miles away too /forums/images/graemlins/frown.gif
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i towed my 72 cross country from california to pennsylvania on a uhaul trailer.they have a specific trailer you have to use for heavier vehicles.the stock weight on my 72 was 4600 pounds,so being over 4000 pounds wsasnt a factor in them letting me rent the uhaul.
  8. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I towed mine from CA to NC. /forums/images/graemlins/angryfire.gif Uhaul wouldn't rent a trailer so had to use Ryder. They offer 2 trailers. One won't fit which is slatted bottom. The other has a full bottom (aluminum if I recall correctly)and will hold it barely. /forums/images/graemlins/woot.gif I had to get some wheels and tires from Junkyard to get it to straddle correctly, but it made the 3000 mile trip. On finding a cheaper moving truck, play the two or three companies against each other even if your set on using one. They will drop prices dramatically. I had a 25' truck and trailer for 800 bucks cross country. I am in the military so know how to save money when doing a long distance move. /forums/images/graemlins/ignore.gif
  9. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    Surprisingly, a loaded 4x4 Ford Explorer 4 door weighs
    almost 250lbs more than my 1990 Blazer (explorer's curb weight is 4891 lbs /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif!!!! kind of surprised me a little bit, wondering where all the weight is since it's def. not in the metal (body panels are made out of aluminum foil on these, speaking from experience....)
    weight taken from http://www.fordonline.net/ford-buyers-guides/ford_explorer.html
  10. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    I want to use ryder, but apparently they don't do one-way trips anymore. The only three I could come up with is uhaul, penske, and budget.
  11. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Ryder/Budget are one in the same now. Budget had bought Ryder. Same equipment from either. If they won't do it then go with Penske. They have the same trailers. Some how U-Haul has their own line of trailers. Good luck and Have fun. A 25' van and trailer with a Blazer are fun to drive.........
  12. blazer74
    blazer74 Member Premium Member
    Oct 18, 2001
    1,154
    74
    Brighton Tn
    I used a penske trailer to tow my 74 1000 miles 6 years ago and the toungue cracked 900 miles into it. They told me the blazer was too heavy, but I did it anyway. Pucker factor was high for the last 100 miles.
  13. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I towed mine on a tow dolly from United Rentals. I went about 300 miles.
  14. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Buy a used trailer for $750 and sell it in Florida for $900 That is the way I have always done it. The key is to buy right and then selling is easy.
  15. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    no time to buy a trailer, and unfortunatly nothing to tow it with. I really don't want to put the miles on the blazer.
    I'm going to give it a shot with the 25 foot truck and car hauler. The weight max is slightly under, but I am going to pull the seats and things out of the blazer and run the tank empty.
    How fast would you cruise with somthing like this? They say no more than 45mph on their site.
    Brian
  16. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i went about 65 with mine and had no problems.my truck was also loaded with a dirtbike and some other things so i know it was overweight. /forums/images/graemlins/eek.gifbut oh well it made it fine.just make sure you check your tiedown points every 300 miles or so.the trailer can be loaded with more weight than they say.they just dont want you to because of liability. /forums/images/graemlins/dunno.gifgood luck with the trip.i did it with 2 cars my truck and the uhaul also my wife mother in one car and 2 dogs and a cat.so everybody got to move.what fun.
  17. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I went as fast as the truck was governed at. Key is just knowing how to handle something that big in case of an emergency. Hitting a grade with that much weight your max speed will be between 30-40. I wouldn't worry about pulling stuff out of the truck. I put stuff in my 79, like the 35's and all my tool boxes. Good Luck.
  18. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    I ended up taking the explorer the first time, because I never measured the tire size and my 33" tires were about 1" too wide to squeeze on. It did okay with the explorer, so I assume the next trip it will do okay with the blazer. There are some steep hills we went up in GA that slowed me down to like 40mph, but most of the way I cruised with the pedal to the floor on the governor at 70mph.
    I have the 6-lug wheels on my 75. Do you how what all years would be compatible to find some wheels and tires? I am going back home next week to fill up another 24' uhaul and try towing this again!
