towing question
Discussion in 'The Garage' started by 99firehawk, Sep 2, 2004.
  1. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I know theres a towing section but figured Id get more responses like this.
    I have a 83 k5 with 35 bfg ats and 6inchs of lift. Im considering pulling a pop up camper 2200lbs 14 ft. Ive never towed with a lifted truck before, Im going about 80 miles, Im in no hurry and have no problems doing 50-55 . Think the ol k5 is up to it? (fresh350, fresh t350 with a towing shift kit and 100%fresh brakes master->wheel cyl. and suspension. )
    tia
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    It is up to it if you can keep the rear of the camper off the highway. Better look into a dropped hitch for that thing.
    (35's on the trailer would solve the problem and be sweet /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif) /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    towing that load will be no problem with your ride but you will probably want a drop hitch.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    im thinking you might need a 8" drop thingy majig. (I dont think a "drop hitch" is the proper term- as this refers to the whole hitch being lower.
  5. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I stand corrected..you need a drop thingamajig. /forums/images/graemlins/wink.gif
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Most people call them drop hitches... and that is what you need.
    Other than that, you should be fine with such a small load behind you.
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya i have always called them droped hitches, but from now on i will use thingamajig /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
  8. 99firehawk
    Dec 15, 2002
    491
    Thanks for the respones guys, Im on my way out now. I have a 7 and 5/8 droped thingamajig and the trailer only sits about an inch higher in the front when its hooked up. I was more concerned with how a lifted short wheel base truck tows, considerign my towing experince id with a gmc club cab dually and a f250 diesel long bed.
    Wish me luck gentle men
  9. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Once you have your drop thingymajig, your all set. Depends on how you did your rear lift- The softer the spring, the more issues you will have-. If you have some stiff rear springs, then your all set. /forums/images/graemlins/thumb.gif
  10. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    With a 2,000lb rolling load you shouldn't even notice it's back there. Especially with a low profile pop up.
  11. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I looked it up eariler, the thingymagig is called a "Hitch Ball mount". More specifically, he is looking for a "Drop hitch ball mount" /forums/images/graemlins/screwy.gif
    You might not notice it back there, but I can tell you from personal experience that flexy springs and pot holes do not make for one fun towing experience.
