towing spring question??
Discussion in 'The Garage' started by twoslo4five0, Feb 7, 2007.
what would yall use for towing??? need 5 inches of lift
  1. shackle flip,with a zero rate
    37.5%
  2. 6 inch springs
    37.5%
  3. 3 inch leaves and 2 inch block
    0 vote(s)
    0.0%
  4. 2 inch spring and 3 inch block
    0 vote(s)
    0.0%
  5. stay with the 5 inch block
    12.5%
  6. go neekid and go to lowes and buy some lumber and start cutting
    12.5%
Multiple votes are allowed.
  1. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    i have a 87 burb i use for towing (as you see in my avatar) it has a 6inch bds lift in front and i have 5 inch blocks in rear...i know,i know 5inch blocks bad idea...thats why im asking for what yall would use 4 towing...gimme input...
  2. twoslo4five0
    Oct 5, 2006
    6,614
    71
    no one gonna chime in on this???
  3. goldwing2000
    goldwing2000 Guest
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Why not keep your stock rear springs and ditch the blocks for a 4" shackle flip and some 1" zero rates?
  5. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    if it was me i would go to a 3 inch spring then go to a spring shop to get it arked more and add a other leaf under the first one going eye to eye(pass the bolt hole)that way u incrase the spring capasity and reduse the risk of breaking the top one near the bushing.And as a bonus u will corect the shackel angle by pithcing it forward a bit.on the down side it will ride a bit harder but it is the price to pay!!!
    keep in mind i work in a spring shop for a living for the past 6 year and you can belive the thing i see all day long!!! some people are just plain stupid sometime.. dont get me started!!!:eek:
    hope it helped a bit
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    2" springs and a shackle flip... should sit aboot level...
    WHy would you want 5" in the rear if you got 6" up front:confused: Especially when burbs have saggy a$$ already...
  7. twoslo4five0
    Oct 5, 2006
    6,614
    71
    i like to have about 2 inches lower in the rear...as jesse james says "thats west coast style"
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    you :screwy::p:
    Anyways... id still go flip/ zero rate or a 2.5" flip, and a 3" spring...
    The flip/ spring would be a better option, imo, because your using a new spring
