Towing the '72 K5?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by wedge, Jan 23, 2003.
  1. wedge
    wedge Registered Member
    Jan 5, 2003
    6
    Michigan
    Towing the \'72 K5?
    Can I tow our 72 K5 with all 4 wheels on the ground? It's a 4WD with 4 speed manual and I get conflicting opinions. /forums/images/graemlins/k5.gif
  2. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    Re: Towing the \'72 K5?
    my 69 K20 is 4WD w/4 speed manual. I got a tow bar ont he front of it and it tows better than any thing else I've towed
  3. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    The only thing I ever heard to do was put the transfer case in neutral.....then go!
    Seemed like a pretty straightforward and "common sense" suggestion, but I'll let someone with BTDT experience give you the final vote!
  4. Tuff
    Tuff Registered Member
    Mar 4, 2002
    77
    Columbia, SC
    I did this from colorado to South carolina and didn't have a problem. However I pulled both drive shafts so nothing could go Wrong. I pulled it with a tow bar and magnet lights.
  5. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I would say beings it a 4-speed and not an automatic. unlock front hubs, put tranny in neutral, t-case in neutral, and disconnect rear driveshaft. so that the u-joints are not spinning. Im not sure if this could hurt anything or not but just preventative thing I spose.
  6. '72brett
    Dec 3, 2002
    166
    northwest Iowa
    for a long trip, taking the drive shafts off would be nice. but short ones, it would be almost pointless and unnecissary I think.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think there is a max weight to flat tow for each state. You might be over it. Other than that just make sure the tow bar is level and that you tow it with a HEAVY truck!
  8. wedge
    Jan 5, 2003
    6
    Michigan
    Thanks Guys! I'm ordering a 10,000# towbar today. We'll pull it with our MH that is a Freightliner Chassis with 330 Cat and 6 sp Allison trans. We have air brakes and a Jake brake but won't use the Jake when towing. I think we'll install remote brakes on the Blazer as well. The only reason we'll tow the Blazer is that we don't want to buy another vehicle to tow. The insurance and plates for the K5 are relatively cheap and it's alot of fun to have around! /forums/images/graemlins/k5.gif
