Towing with 4" rear blocks?
Discussion in 'Tow & Trailer' started by divorced, May 5, 2006.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    1996 K1500
    I just put a 6" lift on the truck. The rear has a 4" block, add-a-leaf, and a 1" zero-rate-type of block and is running the stock tires for now. Can I expect to be able to tow the same amount of weight with the 4" block as I did when it was stock?
    :confused:
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I towed way more weight after I lifted my K5 with 4" blocks, shims, and an add-a-leaf then I did when it was stock.
  3. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Lots of 3/4 and 1ton Dodges have factory blocks under the rear springs. My '98 3/4 ton Dodge does. should only add to the tendency for axle wrap, not affect load capability.
  4. divorced
    Jul 20, 2004
    5,115
    Thanks for the replies. I was mainly checking to be sure the blocks wouldn't fall out from sideways forces when turning. I think a lot of the older Fords have 3" factory blocks, too.
    It sounds like it should all work out fine. :D
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Only unless you leave your ubolts loose I guess.......:haha:
  6. divorced
    Jul 20, 2004
    5,115
    :haha: :haha: :haha:
    I have them torqued to 110 ft lbs right now. The directions said 100 to 120. I still need to drive it and re-torque them.
