Towing with 700R4
Discussion in 'The Garage' started by Mr. Jimmy, Oct 13, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    I am running 4.56 gears,33 inch tires and a 700R4, this setup turns about 2250 RPM at 65 mph.Is it safe to pull a 2500 lbs boat in overdrive if I wire the TCC to stay locked as suggested on the Bowtie overdrive website?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The big problem with towing in OD is that the ATF circulates a lot slower than normal. This allows it to heat up quicker and cool down more slowly. For this reason alone, I never tow in OD.
    I'm not aware of the TCC bypass thingy, so I can't comment. If Bowtie says it works, I guess I can't argue, but I'd be curious to see if they would still warranty a tranny that blew up while towing, regardless of what "measures" the owner took.
    I'm assuming that you're running a good quality auxilliary tranny cooler, BTW.
  3. Can Can
    15,552
    136
    One other thing, brother: FIll in your profile, please. Name, location and truck details will help us help YOU!!! /forums/images/graemlins/thumb.gif
