Towing with a k-5
Discussion in 'The Garage' started by gmcjimmy4x4, Apr 15, 2007.
  1. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    Just wondering how much i can tow with my 91 jimmy. Ive got a 6" lift 37's and 14bff with 5.13 in the rear with disc brakes. Its got a stock 700r4 but only has 40,000 on it. The engine is orignal with 155,00. Also upgraded the rear drivline and u-joints. Does have an engine oil and tranny cooler. Im renting a toy hauler trailer for labor day and not sure what to expect. The trailer is 4980 empty and rated 7000 loaded.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    make sure youve got a big tranny cooler on that 700r4, or itll be toast. you should be able to tow the 7k that the trailer is rated for, but make sure you got the biggest tranny cooler you can find, also dont tow in overdrive (im sure you already knew that)
  3. 1fastchevy
    1fastchevy Registered Member
    Mar 2, 2007
    50
    Houston
    you will be amazed as to what you can pull, you have all the right stuff, do you have trailer brake? it will make a huge difference when it comes to stopping, Dave
  4. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    Will be installing one asap.
  5. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    you can do it, but its not going to be fun. With such a short wheel base your going to be bucking the whole time probably. I would defiantely get some trailor brakes, or that bad boy is going to push you right through an intersection. A bad boy tranny cooler defiantely would not hurt either.
  6. 1fastchevy
    Mar 2, 2007
    50
    Houston
    just make sure to cruize don't get in ahurry, the short wheel base will be a little scarry, check all the tire pressures all the way around even the trialer, I would run them high just to help with the truck and trailer feeling loose( side to side), Dave
