Towing with a shacklt flip?
Discussion in 'OffRoad Design' started by codyoffroad, Oct 30, 2002.
  1. codyoffroad
    codyoffroad Registered Member
    Aug 14, 2002
    6
    Montana
    I am deciding how to lift my truck and I was woundering if it is safe to hull heavy weight or pull a trialer with offroad design's shackle flip
    /forums/images/graemlins/truck.gif
  2. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Search is your friend. This has been covered several times. /forums/images/graemlins/thumb.gif
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The answer is yes with some "but"s. There is a LOT of info in the back posts, do a search here, on the 73-91 board, and on the garage board. Probably more than you wanted to know.
  4. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Re: Towing with a shackle flip?
    I have the same question. Did a search but nothing came up. Cody did you find anything? Also: The ORD web page says the flip kits are for 42 1/2" spring pad centers unless you have a 1 ton. My 3/4 ton has 40 1/2" spring centers, is this a problem? I was looking at kit GU28010.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You will use the GU28010, it's built around the narrower width. There is only a question on the width with the 1-ton in the 2nd gen trucks.
    I ran a search on this and came up with a bunch, are you limiting the search somehow? Maybe the wrong date range or something?
