towing with a short bed?
Discussion in 'Tow & Trailer' started by sled_dog, Nov 30, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    ok I know where I can get a k1500 single cab short bed. I need a daily driver and tow vehicle and am not sure how this would do. I know the springs are too low capacity but an add a leaf or two and some overloads would help wouldn't they?
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    What would You be towing? Add-a-leaves and overloads arn't worth squat if the rear axel isn't up to the job.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The biggest concern you should address is the fact that your tow vehicle is a SWB. You should seriously consider a hitch that is set up with an anti-sway as well as a weight distribution setup. I used to use a Reese system.
    How long/how heavy of a trailer are we talking about, anyway?
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    To add to Canmores post, I would also check the GCWR of the truck. It will need to have at least 7000 lbs extra for a blazer/trailer combination. And I agree with the others that the SWB and half ton axles won't be good for anything other than light towing. Depending on the year, engine, and towing package options the towing capacity should be between 3000 and 7000 lbs.
    Here is a good worksheet for figuring out the actual towing capacity and GVWR.
    BIGJ
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    They key word is stopping ability of the truck. The short wheel base is not so much an issue. It will make backing a little more fun because of the rapid over steer you can have with the shorter wheel base. If you ever decide to pull a fifth wheel type trailer such as a camper, stock trailer, or cargo trailer it can get into the back of the cab if you don't have the trailer altered at the hitch. As with any vehicle if you are going to use a "bumper pull" type hitch make sure you get a good weight distribution hitch.
    John
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Towing what? Blazer?
    NO.
  7. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    Towing with a SWB isn't the best thing to do, but with some mods, you can. I tow with my Jimmy and have no problems. I tow a 24' car hauler filled with atv's, I have towed a blazer on it and I tow my race car/ show car all the time since it isn't street legal. I have electric brakes and I think that is a must.
  8. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    well mountainexplorer is constasntly towing, so i tedn to listen to him. He has towed whith a blazer and said that it wasnt much fun. He only uses his little crewcab or his 3/4ton suburban for towing.
    I have used my f-150 to flat tow my 78 luv to storage and even whith out the motor i knew it was back there the one time i had to stop fast. Just something to bear in mind(granted there was no tongue wieght but still something to think of)
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Not to disagree that short beds and blazers are not the best for towing but flat towing is completely different.
    I flat tow my blazer with my crew cab and it still pushes it around, it's not funny.
    /forums/images/graemlins/eek.gif
    Now I towed a big boat with my regular cab long bed and the brakes and the balanced tongue weight made it unperceptible.
    I am getting a trailer as soon as i can decide which one to get or make one myself.
    /forums/images/graemlins/thumb.gif
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I second the weight distrubtion/anti sway setup.
    I tow my trailer with my race car on it- light night and day with the setup. ITs the difference between being safe, and being stupid.
