Towing with big tires
Discussion in 'Tow & Trailer' started by SS66, Mar 26, 2004.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Do you guys think there would be too much strain on a k30's drivetrain if it were turning 44 inch tires while hauling a boat? The estimated weight of this boat+trailer is MAYBE 1100 lbs tops. Tongue weight of almost nothing <100 lbs.
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    All depends on your gearing. I think you would be fine, but just be careful of sway.
  3. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    The gears would be 5.13 /forums/images/graemlins/thumb.gif
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I wouldn't worry much about the drivetrain in this situation but the vehicle itself and how it's setup.
    Is the drivetrain in a K5 or in the original truck?
    Is it lifted too high?
    What I am getting at is sway and and squat.
  5. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    This hypothetical k30's only mod is a 4 or 6 inch lift along with the big tires and 5.13 gears. Its a real k30, not something that was parted together. Im guessing things probably would be 'ok'. I just wanted to see what the tow guru's thought. /forums/images/graemlins/waytogo.gif
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    1100 pounds? You wont even know its back there.
