Toyota question
Discussion in 'The Garage' started by CaveBlazin, Mar 8, 2003.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    My buddie has a 91 yota 4x4 with a 5speed and a 4 banger. When you excel starting from 1st you get a nice loud squeal but it does'nt do it in the other gears. But it does do it when you downshift in all the gears I thought belt or something but they seem ok what are some ideas on this. Thanks in advance...
    Spence
  2. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    bad bearing on alternator,ps pump,water pump,smog pump, tensionor???? just some ideas, I'd spray some dressing on the belt first though, might be old and hard?
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    when i had a yota that noise was the start of a throw out bearing /forums/images/graemlins/usaflag.gif
  4. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Are you sure the belt(s) are tight enough? The Toyotas like em real tight or they'll squeal. If that's not it, I second the throwout bearing.
