TPI/400 small block WILL IT FIT??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 71Blazer, Apr 14, 2002.
  1. 71Blazer
    71Blazer Registered Member
    Dec 17, 2001
    24
    Coupeville, WA
    Anyone ever heard of or actually combined TPI with a 400 small block?
    I just discovered my 350 is really a 400 which is not bad but now do I have a TPI that won't fit? (That would be very bad/expensive discovery)
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    With the long small diameter runners on that thing you would have all sorts of low end torque!...it would just take a dive at around 4000 rpm. If I had the cash I would try it.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    frank (blazinor) has a 400 bored .30 over=406 and has a tpi setup on his and man is it sweet /forums/images/icons/smile.gif pm him with any???? you might have /forums/images/icons/smile.gif
  4. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Yes I run one with a aftermarkit intake which is biger than the GM one
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Only thing is the heads need the steam holes drilled..........and it does not die at 4000, at least mine doesn't - pulls quite nicely to 4500+.
    You have a better situation than you thought, amigo.
  6. 71Blazer
    Dec 17, 2001
    24
    Coupeville, WA
    What is involved in drilling out the steam holes on the heads?
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You just place a head gasket on the head and drill out the holes (to the same size that the gasket has) that should be in between the cylinders.
  8. 71Blazer
    Dec 17, 2001
    24
    Coupeville, WA
    Chalk it up to dumb luck. How often does a project really work out better than expected? Yahoo!!!
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Unless you are going to swap heads, you already have the steam holes.
  10. BurbinOR
    5,829
    Oregon
    He more than likely need to swap heads if he has a post 87 TPI setup, as the intake mount holes changed that year.
  11. Blazer1970
    1,600
    Old Mission, MI
    It is real easy to modify the intake (TPI base in this case) to bolt to the older style heads. It is just the angle of the center two bolt holes on each side.
  12. 71Blazer
    Dec 17, 2001
    24
    Coupeville, WA
    It's an '86 corvette setup converted to speed density. Should bolt right up nicely. It comes with an Accel DFI so I can tune it to my liking... after some trial and error to be sure. BTW thanks for the input!
  13. BurbinOR
    5,829
    Oregon
    Cool, keep us posted..............
