TPI Air Filter
Discussion in 'The Garage' started by 1979jimmy350, Mar 5, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Thoes with TPI in there truck what are you using for a air filter? Post up a pic i am trying to figure out what i am going to use for a air filter
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm using the stock GTA Trans Am filter setup. It does a 90 degree turn towards the drivers fender, then down into a round filter housing.
    There are pics down towards the bottom of my web page:
    http://www.angelfire.com/super/ThunderTruck/ :cool1:
  3. dyeager535
    26,980
    Great minds must think alike! lol :)
    Pics of my setup are here, http://dyeager535.topcities.com/TPI/index.html First page, all labeled "air...jpg"
    Only difference on mine is that I have a drivers side battery tray that was not being used, so I mounted the aircleaner to it (imagine that, hole in bottom of air cleaner housing lined up with the battery hold down clamp) I don't have any "after" pictures now that it's completed, but you can see where the flared end of the air cleaner is facing the core support, but open.
    The stock plastic air cleaner snorkel from the 80's carbed applications is the perfect donor. I moved the snorkel to radiator support "connector" from the passenger side to drivers side, (same on both sides, just remove the plate that is tacked in place) the "connector" is visible in some of the pics if you look closely. Rotated the TPI filter housing so it was angled approx. 45* towards the radiator support snorkel connector, cut the carbed end of the stock plastic snorkel off until it was the right length, and slid it over the flared end of the TPI intake. Now it gets "outside air" as was stock, and you don't need to use any clamps as the flare on the TPI filter housing is a perfect tight fit in the carbed snorkel. (besides, it's solidly mounted and won't move)
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Those look great, but your engine is sucking 200 degree air right out of the radiator. :(
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have a K&N filter on the end of my MAF sensor.
    Harley
  8. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    I'm running a stock Trans Am air box, cept where the MAF used to be hooked up to it, I've got a cone filter. Amazingly enough, the cone filter wound up sitting right behind the hole in the core support, so it sucks cold air, instead of hot rad air :D
    I don't have a filter on in this pic, but this is what my TPI looks like as of the last time I had it together (still had an automatic behind it, and a MAF system, lol) :D
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  10. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I moved the battery to the left side and put the stock 89 TA air cleaner on the tray where the battery originally was and there is hole in the radiator support there to get some cool air.
  11. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    here is mine. i have fab'd a sheild for it just need to install it.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That's purty stuff! Where did you get the nice tubing and rubber elbows?
  13. beater74
    May 29, 2001
    1,749
    atlanta
  14. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Just an FYI for the guys running a MAF. If you run a K&N that has just been cleaned and oiled, some of that oil can coat the wire in the MAF, making your truck run like crap. I found this out the hard way on my IROC..
  15. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
