TPI and 4L80E combo- anyone run this?
Discussion in 'The Garage' started by COCHEV, Mar 8, 2005.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i have a 95 silverado pickup with tbi and 4l80e trannie. i'd like to swap over to tpi for some more torque and a little coolness factor:p: . will i have to get the stand alone 4l80e trannie harness or will an ecm from a tpi/700r combo be able to manage the trannie? thanks,
    jason
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    I plan to run the same combo :)
    You will need a stand alone controller for the 4l80e though. Keep in mind that TPI will not flow well above 4800 RPM on a stock 350, with higher performance machines being worse. You'll need to upgrade the intake / injectors / programming for a higher performance setup :)
  3. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    not worried about the higher rpms on this application. its my daily driver. everything i've read about tpi says its awesome on torque, so that why i want to do it. i have a mild truck cam already and want to put some slightly better heads on too. thanks for the input,
    jason
  4. dyeager535
    26,975
