tpi computers difference?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BIGRIG, Aug 27, 2001.
  1. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    What is the difference between the vette #01227727 and the camaro #01227730 ecm's?
    I have an 86 manifold so I can use the old heads and the newer plenum and tubes so theres no cold stat inj. or maf........ which one should I go with?
    Thanx
    Chris C
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I belive the vette computor is set up for a bigger cam and more compression. Other than that I belive they are the same. Either one will work. If you have both of them, then try each of them and see which on you like.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Depends on what year they are from. The earlier Camaro ones (don't know about the Vette ones [​IMG]) prior to '89 are different as they are for the MAF systems. Sorry, don't know what year your part numbers match up with. For a Speed Density setup you need the later model computer.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  4. BIGRIG
    Feb 29, 2000
    488
    Independence, MO
    Desertdueler: thanks I think thats what I'm lookin for but the plugs are different; one with three and one with four plugs. Also i'm going to buy off ebay.
    BlazinOR:Both computers are from late models and are for speed density but there are two different numbers? Which one did you use in your setup? BTW good lookin rig saw some pics on interior and engine looks sweet!
    Chris C
    Thanx guys
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!&lt;img src="http://coloradok5.com/forums/images/icons/tongue.gif"&gt;
