TPI Conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Apr 6, 2000.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I think I posted this on the old board, but I think we were in the process of converting. Anyways I have a access to a Tpi system wiring harness sensors everything from a (305) Trans Am. I am curious how hard the conversion from my Tbi unit in my 87' K5 would be? Has anyone done this or know of any material online to help me out. Is it as simple as swaping fuel pumps, harness, sensors, and intakes??? Any help you can give is greatly apprieciated.
  2. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    You got it man that all you need. Oh you need a white nose knox sensor you 87 has a black nose one.
    88Jimmy 350 Vortec TPI
  3. 88Jimmy
    100
    Las vegas, NV
    Oh you can use the Map sensor off you 87 too!
  4. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    The four center intake bolt holes on the TPI, are vertical, not at an angle. You will have to drill them out to fit your motor. As long as you have the complete harness,sensors and ECM you should be fine. Painless Wiring makes a harness for about $300. There is a book about the conversion called TPI swap. I did mine about 9 yrs agao and love it. The only thing I would probalby do different is not to put the Electric fuel pump in the tank. When you get low on fuel and turn a certain way the fuel pump is starved and the truck cuts out until it gets fuel. You should get a High flow in-line fuel pump. AZ TPI sells a nice set up for about $150. Give them a call or look up their web site at ArizonaTPI specialist, they are in Tempe, AZ They also sell the book
    Good luck
  5. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    What about a prom chip? The camaro chip won't be right will it? Is an aftermarket part available?
    John
    So Much to do, So LITTLE cash.
  6. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    On mine TPI I am using the Camaro Prom. My buddy bought one configured to his motor hp, cam etc. The Corvette, Camaro, Firebird prom will work fine. I am using the whole camaro motor assembly and all. You just need to know how to hook up a couple of wires, check engine wire light to the existing harness. The Blazer ECU will be tossed
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    My 79 has the IROC '87 TPI in its' entirety on my 406 SB.....used the exact same sensors, computer, etc. Used the Painles Wiring harness (price was just at $300, as noted above) and it dropped in slick. Had to cut a hole in the exhaust as my truck was obviously pre-computer, but all in all went easy. Used the IROC heads so no drilling was required, only the steam vents. MUCH better than a Q-Jet, and probably way better than TBI. That TPI book "Chevy TPI Fuel Injection Swapper's Guide" by John Baechtel is very good, and informative. Lots of neat ideas in it. Worth the $16.95.
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  8. BlazerBoy
    639
    Chicago IL.
    Will the injectors from a (305) be large enough for my (350)???? Thanks
  9. 88Jimmy
    100
    Las vegas, NV
    Yes they will work
    305 came with 22lb
    350 came with 24lb
  10. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    88Jimmy
    Where do you find this info?
    Brian
    Still in search of the TBI KING!!
  11. BurbinOR
    5,829
    Oregon
    Yep, my 406 has no problem with the stock 350 injectors. I also don't rev it to 6000 RPM, so not sure if it would starve up there...........no need for me to rev it like that.
  12. 88Jimmy
    100
    Las vegas, NV
    Two good books are Chevrolet Fuel Injection by Motobook and
    Chevy TPI Fuel Injection Swapper's Guide By John Baechtel
    I got my TPI from Jim's performance and spent hours on the phone with him.
    I had Jim's Performance do my wiring harness he took my TBI harness and changed it to TPI for only $150.00
    Jim is the one that told me about the knox sensor it was not in the books. But then again he does this for a living!
  13. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    TBI manifolds and heads have the four center bolts on the intake vertical, like the TPI.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  14. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I've been kicking this idea around for a while too, I have access to the top half of an 87 Iroc 350. I just wish I had more time.
    Joe
    88 Jimmy
  15. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Another book I came across is SunCoast Conversions "Tuned portHandbook", found it to be very informative. It gives wiring specifics where I was told others didn't, just sent you looking elsewhere. I did an S-10 swap, and I'm currently hunting a good deal on a tpi setup now for my 70K5. What are you guys paying? I can find them for $300, but I think a better deal can be found. Last year they were bringing $100- 150.
  16. 88Jimmy
    100
    Las vegas, NV
