Tpi fuel injector clips
Discussion in 'The Garage' started by NoSmog73, May 8, 2005.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    When I got my tpi set up I didnt know it did not have the little clips that hold the injector into the fuel rail and I was wondering if anyone has the part number of a pic of what they are to look like...Thanks
  2. dyeager535
    26,980
    I *think* there are two different types of clips. What year are you dealing with?
    My '88's use a clip that snaps into the groove on the injector, and has two "tabs" that stick out from it that you use to rotate it into the "lock" position. Don't have pics, sorry.
    I've seen it stated (and in practice) more than once they are unnecessary once the rail is bolted down, as they can't go anywhere.
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Thanks for the reply..
    I went to OSH today and found a pin clip that will work I think..
    I started to think that the fuel rail would hold them in place and didnt see the need for the clips but I went with these accel injectors and they are a tad 1/8" shorter then stockers and was kinda worried about the pressure moving them as the pulse from the fuel and in turn wearing out the o-rings
    Plus the accels come with a few grooves in the top of the injector for a universal fit...lol
    So I have to pin them in on the top slot in the injector..
    Thanks again for the info.. :waytogo:
  4. dyeager535
    26,980
    Keep your eye on those injectors. Have a pretty bad reputation over at thirdgen.org. As with everything, they seem to work fine for some, horrid for others.
