TPI Guys Fuel pump question
Discussion in 'The Garage' started by primerk5, Aug 28, 2006.
  1. primerk5
    primerk5 1/2 ton status
    Jan 13, 2001
    220
    Finksburg MD
    I'm getting ready to install a TPI system on my truck. Here is the dilemma. My truck has dual tanks. I would greatly like to keep this. (even though one has a hole in it.) Do I have to use a Intank fuel pump or is there a inline fuel pump that can pull the fuel up to it and pressurize it on the other side of the pump?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    You'll find that most inline fuel pumps are designed to push fuel, not pull it. It probally could be done for a while, but don't expect the pump to last very long.
    Its probally easiest / cheapest to buy yourself a set of 87 TBI tanks, a set of TPI fuel pumps, and a high pressure switching valve.
  3. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    tbi tank or tanks. switcher valve for tbi . then grab a fuel pump or 2 for a tpi car like camaro. then install on truck sender. 90% of the gm pumps are the same phisycle size and plugs. just put out more pressure and volume.
  4. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    This should work...
    The best approach is to use the in-tank fuel pumps as mentioned by the others however; an alternative method that should work is shown in the attached diagram.
    A better alternative to the diagram I attached is to use two external pumps plumbed in between the selector valve and the tank, and swith the power to the pump with the tank selector switch.
    I have never plumbed two tanks this way, but I have been running my TBI fuel system this way with one tank with no problems for 3 years now. The only difference is the addition of the selector valve, which should not affect the pump performance much as long as it was from an EFI truck. You also want the pump as close to the tanks as possible.
    I personally like having the external pump. It's really easy to access and change, of course if you buy a Walbro you'll probably never have to change it:)
  5. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    This is what Holley recomends (pages 12-13):
    http://www.holley.com/data/Products/Technical/199R10179-2.pdf
  6. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    thanks that holy information will come in handy when doing this fuel changeover. I will may look into sweetk30's idea as well. But wait?, On the holy diagram it shows a fuelpump that looks as if it is external. Why couldn't I put this on the engine side of the switch?
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    With just a hi pressure pump my k5 will surge for fuel below 1/3 of a tank of gas or so when cornering hard or under hard acceleration.
    When i swapped to my GenIII 6.0L I put in a low pressure fuel pump to feed a surge caniser, then a hi pressure fuel pump right out of the bottom of the surge canister feeding the fuel rail/regulator. Works awsome, never surges, and when you run out of gas, you are OUT of gas!
    Good luck.
  8. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    Yes. The holley plumbing scheme uses external fuel pumps.
  9. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    Ok then like I asked, would I be able to use one of these holy pumps on the engine side of the factory fuel tank switch and then run presure line from the pump all the way to the engine. Also Will these pumps last? As to the reply/quote from SierraClassic?
  10. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    Use a Walbro external pump and you should be fine. Make sure you by one rated for high pressure one that can provide enough flowrate for you engine.
    The key to the external pump is a large enough fuel ID on the inlet side, minimize the distance from the tank to the pump, and keep the pump below or at the level of the tank bottom. If you haveproblems with only one pump you will need to buy a second one and plumb it the way that Holley suggests.
  11. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    Sounds like a plan. As soon as I get My wiring harness I'll see if I can make this stuff work. Thanks again
