TPI guys
Discussion in 'The Garage' started by Ruthven13, Apr 14, 2006.
  1. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    Just working on finishing up my TPI project in my '91 Jimmy and have a question for those who have done the conversion. What upper radiator hose did you use and did you incorporate an electric fan? I am using the stock fan for now so I ned a hose that will clear the shroud and the like. Thanks!~
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well I did mine on a 72 and I used the stock hose, just a different thermostat housing. Is your upper hose on the drivers or passengers side? You can sort of see it here, I can take better pictures, but Im sure theres someone with a newer chev like yours that would be better help.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    I got a rad hose from a mid 80s caddy. It has the pefect bend to go around my acessories, and enter from the back side of the intake. I've got some cheap Mr Gasket 4.3 chrome water neck on my truck at the moment, but intend to replace it with a stock 4.3 chrome waterneck from an S-10.
  4. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    What all is involved in this setup? I have a 92 Z28 sittin in my drivway with a complete setup in it. Maybe Ill strip it? :D
    ~Brian
  5. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Putting an IROK TPI in my Cruiser next month.....
    Should be fun.....Anyone here ever ran a C4 behind a Chevy? It is the shortest auto of any quality ever made, T400 leaves a 10" driveshaft on a Cruiser, T350 and 700R aren't much better, the C4 is only 20.25" long with the shorty kit.
    Go ahead and flame away for suggesting a Ford Tranny behind a Chevy motor, I am prepared for it. I really don't make much distinction between parts sources any more, who drives anything stock anyway.
