TPI idle bump question
Discussion in 'The Garage' started by Hossbaby50, Jan 16, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    For offroading I would like to be able to bump my idle up a little. With my TPI the ECM controls the idle for the most part. Is there anyway to get the computer to bump the idle up? I know Rob (therobzilla) has an system threw his IAC that will bump the idle up. I was thinking though that since I am not using Air Conditioning I could use that wire to make the computer think the AC is on and its idle should go up. Would this work, and if so do I just put a 12v wire on a toggle to the AC wire for the TPI computer?
    Harley
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It sounds ok, just never thought of that. I wonder if there would be any way of making a bracket and adapting the solenoid from a a/c equipped car/truck that pushes the linkage up a bit. My carbed truck has one and the solenoid just uses 12v to hold it. If the way you asked about didn't work out you could try that. /forums/images/graemlins/k5.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You don't even need 12 volts. The a/c "ON" switch just closes a circuit that grounds the a/c request signal to the ECM. Ground that wire through a switch and you'll be all set. But I don't know how much difference it makes offhand.
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Like Harry said, not sure if it would really bump it up much if at all. Not sure how it increases the idle, since all it seemed to do was bring it back to the standard idle on mine. Hmmm, good question.
    Why do you feel the need to bump it up?
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    For offroad. That way if I need just a little more RPM to crawl over something I don't have to use the throttle, just kick the switch for a little extra rpm & power. I am going to look into the hand throttle setup Rob has that uses the IAC to bump the idle. It is pretty trick. I got to see it in use again today and it is sweet. Thanks
    Harley
  6. BurbinOR
    5,829
    Oregon
    Harley
    Hand throttle would be the way to go - don't think you could get the idle up high enough with 'trickery'. /forums/images/graemlins/grin.gif
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    No, but with the AC thing I might get up to 750-800 RPM which would be nice just until I get the money together for the hand throttle setup like Rob has.
  8. BurbinOR
    5,829
    Oregon
    Keep us posted - would love to learn how that is done. /forums/images/graemlins/deal.gif
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  10. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    The offroadengineering electronic idle controler works much better than a hand throttle. The electronic "Trickery" that this system uses is a well designed system. It controls the idle for both the high idle and the lower idle. I use this on a very frequent basis, and I have had no problems with it.
    The problem with a hand throttle on a TPI is there is almost no room for linkage that does not get in the way of the kickdown and the actual foot throttle cable, and you have to spend the extra money with Lokar for the 3 cable plate that attaches to the side of the plenum. The other issuse with at least my old hand throttle setup was that when my blazer is climbing and totally twisted up in the rocks, I could never get the cable for the hand throttle not to bind up. When it get really flexed up, it would have a tendancy to pull back on the hand throttle cable on it's own, thus making for a very dangerous situiation with accelleration when you don't want it crawling in the rocks. This being caused by body to frame flex.
    I also us the to run my air compressor for trail repair and for controling the speed and idle gowing down steep trails and switchbacks. Between the doubler and the Idle controler I can litterally creep at a much slower rate than just about anything.
    Rob
