Tpi manifold fitamint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Swifty, May 6, 2003.
  1. Swifty
    Swifty Registered Member
    May 10, 2001
    43
    Livermore Ca
    Will stock tpi manifolds from I think is a 90 Friebird fit on my 79 350? Thanks.
  2. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    not without just a little bit of work. The 2 center bolts on the manifold are at a slightly different angle, but that is an easy fix, by either grinding or I've seen some use a tapered washer that worked great.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    hmm good question....
    I put a '87 camaro carb intake on my 1991 caprice police motor which was tbi....
    yeah the 4 center bolts in my intake are straight up and down..... that is why i went with the '87 camaro intake.... you can drill out the holes.. but check first because we did this on one of these motors exactly the same as what i have and the ports in the intake didnt quite line up.. that setup is in a '86z-28 which is gettin rebuilt anyway.....
