tpi manifold hole
Discussion in 'The Garage' started by PeteH, Apr 25, 2006.
  1. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    what are these holes and i notice alot of people run their fuel lines with rubber hoses(the fuel injection hose) but what are you doing to barb the ends or are you just cutting them and adding hose and clamps..seems bit unsafe? and what filters are you running before and after you elctric pump(those with inline pump) i'm sooo close.. tomr i would like to get it running.[​IMG]
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i dunno, cant remember
    www.thirdgen.org
    all the tpi info you can shake a stick at
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    The hole on the right is the PVC port. Normally there is a nipple threaded into that hole, and the PVC line runs from it to the valve on your valve cover.
    No idea what the hole is on the left, I'll look at my intake tommorow and let you know.
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I agree with Sierra,PVC port.
    The bolt hole is just used for the manifold bolt,no bracket that I'm aware of.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    I was wrong on that bolt hole.
    Looks like a hose bracket goes there.
  6. dyeager535
    26,979
    How about AC compressor bracket? My guess. :)
  7. PeteH
    Mar 26, 2003
    498
    San Jose
    yea i searched on thirdgen...saw pictures of the nipple but didnt know what it was attatched to.
  8. PeteH
    Mar 26, 2003
    498
    San Jose
    thanks guys..
    for those of you with inline pumps what filter are you running before the pump?
    crap..one more Q's...what the hell do i do with the park nutral sfty switch coming off my comp? my 75 just has a th350....rrrggg
  9. Russell
    Jun 23, 2000
    7,923
    333
    Park neutral switch is on the foot of your steering column. It keep the engine from cranking in gear. The wires for the switch are yellow and purple. You'll need to connect the ECM to the purple wire.
    Same goes for a standard transmission, cept you use the purple wire off the clutch switch.
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I use 2 filters. 1 prepump, 1 postpump. You can run any inline filter before the pump but after the pump you need one rated for FI. I am using a clear Fram G3 filter prepump and a filter from a 92 Ford F350 w/7.5L motor.
    The fuel lines on my motor are rubber like you mentioned. There are special fittings (saginaw to AN) fittings that you can buy to convert the fuel rails fittings from GM Saginaw style to AN fittings. After you convert it to AN you can put AN hose barbs on there and you have some nice safe connections. Some people cut off the fuel lines and flare them to put lines on and that is kinda sketchy to me.
    Harley
  11. PeteH
    Mar 26, 2003
    498
    San Jose
    sweet..thats what i thought. i have most of fittings including to convert to AN. and i just figured out that one could actually double flare themselves(i would only use that for before pump or even parts for return)
    thanks for the help you guys.
  12. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Yes, I know this is an old thread, but I did not want to start a new one. Where can I find the sizes for AN fittings? In other words, is AN 10 about 3/4 of an inch in diameter?
    Also, I hear that running a filter before an inline pump could lead to fuel starvation and a short life for the pump...thoughts?
  13. Russell
    Jun 23, 2000
    7,923
    333
    Your pump already has a filter before it, the sock filter in the tank. And yeah, it is hard on the pump to have one there. Pumps are really good at pushing fuel, but suck at pulling fuel, so if they have to pull fuel through a restriction like a filter, it will make it work much harder than it needs to.
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Thats PCV, not the other way around.
    Positive Crankcase Ventilation
    PVC is the plastic pipe in plumbing...polysomethingsomethingsomething.
  16. Russell
    Jun 23, 2000
    7,923
    333
    Sorry -- I do know the difference, just semi-dyslexic at times :doah:
  17. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    me too!..
    I sometimes mix up the letters too,even though I know better!..:blush:
    The best ones I heard was at the parts stores..
    "Do you have a PCP valve for my car"??... "a PCP valve!..hell no,that stuff's illeagal!":haha:
    "How much is a Caddilac converter for my car"...:rolleyes:
    "I need a "Mission Control" valve!"..:p:
    "Do you guys stock ERG valves":confused:
    and then there was the Chinese guy who asked me for "Rocking Rug Nuts"..It was all I could do not to bust out laughing!..:bow:
