Tpi manifold
Discussion in 'The Garage' started by tunedportk5, Jul 21, 2004.
  1. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I have a 89 Tpi set up and I'm going to get a 85 or 86 intake so it will bolt up to my stock heads and I need to know if the runners and every thing else will bolt up the same.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    it should as long as the 89 setup is a MAF setup which it should be.
    You know you can have the 89 manifold machined out to fit your 85 style heads. I reamed mine out with an air grinder with a drill bit in it. It was a PITA but I got it done and it is working fine.
    A cylinder head shop or machine shop can probably redrill those holes pretty easily and cheaply.
    Harley
  3. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    do you have to grind the top of the intake your just ream the hole and thats it, cause aren't they at a diffrent angle.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You have to take quite a bit of meat out of the manifold and open the holes up to the proper angle. there is nothing really special about it, grind it out alot then try to fit it. If it doesn't fit pull it off and grind it out some more.
    I would call a local cylinder head shop and see how much they would charge to ream out the holes.
    Doing it myself was a huge pain in the ass.
    Harley
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you can get the 85 or 86 manifold cheap then that would be ok but I wouldn't pay alot of money for it. I would have the 89 reamed.
    Harley
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Hey, I happen to be very local to you and can have this done for you for about $40.00. PM me and we can meet up.
  7. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    I have everything to do it i was thinking it might be easier to find a older manifold may be I'll give it a try and if i screw it up then I'll get the older one
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Whatever you wish to do. I live near Decoto/Paseo Padre in Fremont so if you decide to meet up I am sure you aren't too far away. /forums/images/graemlins/thumb.gif
  9. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    $40 might be worth it sence I haven't done one yet and GM sport wants $125 for the manifold, I contact you about it.
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    $40 is TOTALLY worth it. If I had it to do over I would fork of the $40 to have it reamed out. It was a huge PITA. I didn't know that at the time so I learned the hard way.
    Harley
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You can call me at work anytime between 8:00am-5:00pm M-F, or 9:00am-3:00pm on saturdays at 796-2600.
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    WHAT they told me less then that.
    Anyway, I had to do this to my manifold. Im in Castro Valley, if you want you can borrow my burr to open the holes and cut the angles into it its a piece of cake, also, you can check out my manifold too if you want. Let me know.
  13. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Who told you less than that? Are you talking about GM sport salvage about the $125.00 manifold or are you talking about me giving a lower price to have the manifold machined?
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    NO, NO, sorry. GM Sports. I think it was like 70 bucks or something.
  15. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I don't think GM sports sells anything for less than $100.00, kinda like a Harley Davidson, HD = Hundred Dollars /forums/images/graemlins/rotfl.gif
  16. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    HAHA /forums/images/graemlins/rotfl.gif No kidding. I asked them about a TPI setup , they wanted 650, OUCH!
  17. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    I've seen complete set ups in pick your part, and pull a couple times
  18. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    How much? How much did you get yours for?
