TPI MPG Update
Discussion in 'The Garage' started by Hossbaby50, Feb 8, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I got a chance to do a miles per gallon on my TPI today. I filled my tank yesterday and went for a drive today. 80% highway 20% street.
    12.75 MPG /forums/images/graemlins/peace.gif
    It could be better but I laid down the hammer some while on the street and a little on the highway too. It is alot better then the 8-10 mpg I used to get with my carb.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Dang! I seriously need to go to TPI!! /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    So now your going to have to save up for the new tires that your leaving behind as you enjoy your new found power..... /forums/images/graemlins/histerical.gifLOL /forums/images/graemlins/histerical.gif..... Sounds great..... Were you into it a lot with that increase or just once in a while like you first stated? /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif
    About how much and long did it take you to finish swap? /forums/images/graemlins/ears.gif Recommandations are greatly excepted, just not always done /forums/images/graemlins/thinking.gif.....hehehehehehe /forums/images/graemlins/whistling.gif
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Sounds about right. What did you do for speedo correction and tire size differences?
    I got 14 one tank on the freeway, cruise control set, running 60-65 GPS verified. Usually around town it was 11 with my 406.........and no fear of using the hammer. /forums/images/graemlins/yikes.gif
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was into it more then I needed to be at the beginning. It was partly my excitement with the extra power and partly a tuning problem. I had to readjust my throttle body blades and TPS and I also moved my throttle linkage to a lower post so I would get more throttle control. I was having a problem with off idle and slow speed control which I had to fix. It is fine now.
    It ended up taking about 3 months total on the swap, but it didn't have to take that long. There was periods where I didn't touch my truck for 2 weeks. My biggest thing was the lack of knowledge about the system when I jumped into the swap. I was trying to learn on the run and it doesn't work that well.
    BurbinOr: My speedo is actually pretty close to stock form. I did use mileposts to see how much my speedo is off and it is only a tenth of a mile off per mile so I used that in my MPG calculations. So yes there is an error factor in my mileage I am sure but it is not that much. One day I will verify on GPS when I get it.
    Harley
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    P.S. Since the TPI has went in I haven't had any tanks under 10 MPG even in city driving with my foot in it. With my carb I would get 7-8. This motor brand new with good carb and distributor never did anything above 10 mpg except a few times when I drafted off tractor trailers on the highway.
    Harley
  7. BurbinOR
    5,829
    Oregon
    Harley
    LOL, what a great feeling, huh. You've done quite a job getting that project up and running, should be proud. Not an easy undertaking considering your lack of knowledge at the beginning. /forums/images/graemlins/thumb.gif
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am proud. thank you. I wish I would have known then what I know now. It would have been easy (er). For me the hard part is the wiring. I am (was not) that good with wiring. The mechanical end was no problem at all. I just had to learn what all the wires, sensors, and connectors and what everything does. It was good that it didn't start right away so I had to learn to troubleshoot everything instead of trying to learn on the side of the road somewhere.
    Knowledge is key to this swap, I didn't have any so it was alot harder then it really is. I am just glad I had all the help from the people here otherwise it probably still wouldn't be running.
    Harley
