TPI on too my 80s 350
Discussion in 'The Garage' started by 84CUCV, May 8, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I can get a complete TPI set up for a good price. It there anyway to put it on?
    thx mike
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
  3. dyeager535
    26,979
    Need to know year and specs.
    Ryan's writeup is good, but it still depends on year and application on what you can possibly use and what you'd need to buy.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK the tpi set up i found is way different then that one. The one I found is of a 88 1/2 ton 4x4 sub. I can get all of it off this. The owner said there is something wrong with the bottom end in the 350. So he is parting it out. I can get the heads to if I need them. I was going to try to put it into a 1980 3/4 ton 4x4 w/ a 4spd if it matters. the 350 in there has a cam, (no idea what thow) intake and 1405 on it. I am the third owner of this truck, so I have no idea whats in there.
    Any other help would be great!
    thanks mike
  5. dyeager535
    26,979
    In other words, you've found a TBI setup.
    That's about as "plug and play" as you are going to get for fuel injecting one of our trucks.
    To make it clean, I'd "update" your truck with the newer wiring harness to include fuse panel since it sounds like that would be available, and getting uncut harnesses is difficult, assuming it is uncut.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks, i really thought it was a tpi. Shows what i know. What does tbi stand for? anything else i should grap off the truck?
    thx mike
  7. dyeager535
    26,979
    Throttle Body Injection
    Grab every piece of equipment that wiring connects to, and of course all the wiring. Don't cut anything. Take your time. Then worry about what it all does. :)
