TPI sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crashfirepm53, Jun 16, 2004.
  1. crashfirepm53
    crashfirepm53 Registered Member
    Mar 14, 2004
    62
    florida
    Where is the TPI sensor and how/what is the setting volts for it? Thanks.
  2. crashfirepm53
    Mar 14, 2004
    62
    florida
    Sorry. I meant TPS.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    For throttle body? It should be on the opposite side if the throttle linkage I belive. 3 Wires to it, signal, 5v ref, and ground.
    .5V to 4.5V WOT
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Loosen up the two screws and move the tps until you obtain your .54 volts with the key on but the engine off. Tighten it back up while maintaining that setting.
