TPI swap
Discussion in 'The Garage' started by FatBoyBlazer, May 4, 2003.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    my friend just blew the motor in his IROC (86) and its tune port my blazer is a 91 and its TBI...i've got the whole motor to get what ever i need...what should i grab /forums/images/graemlins/k5.gif
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Everything!
    Intake (all of it including the filter housing)
    Sensors
    Wire Harness
    Computer
    manifolds (w/ a short section of down pipe left on them)
    Block
    Intake Manifold
    Dist.
    Accessories with brackets
    Transmission (why not?)
    On a 86 there is no VATS or I would say take the steering column
  3. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Ok, If you have the TBI most of the sensors are the same, ESC, water temp, TPS, IAC, oil press etc. The distributor is the same. They both use a single 02 sensor, so u don't need the exhaust manifolds. You'll need the in tank fuel pump. Route the fuel lines to the front of the block. You'll need a the throttle body, plenum, intake, injectors, fuel rail, computer, and wiring harness. A custom upper radiator hose, throttle cable. Use a tranny TV cable from the camaro. That's all I can think of for now.
    Mike
  4. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    do you have any links to any sites where i can get some pics of the swap...thanks, ryan /forums/images/graemlins/k5.gif
  5. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    this guy's got a good one. you may have to join, it's free, to view though
    tpi swap
