TPI TBI CCC troubleshooting, data (codes, wiring, swaps etc)
Discussion in 'The Garage' started by dyeager535, Jun 21, 2005.
  1. dyeager535
    26,976
    11-11-05
    Updated with ALDL cable links
    OK, finally got the time/inclination to do something for those that don't have service manuals, or those that do and just don't want to scan this stuff in, or want to read it at work, etc. :)
    As you will see, Trickster over on thirdgen.org has been nice enough to scan all of these charts in. Be forewarned, these are F-body diagrams, so you TBI/CCC folks should be careful, but you will find most things are identical I'm sure.
    Not complete of course, but at least everything I could find is now in one post. I will update as I find more. PM me (if you can) and have more charts to add, that way the thread doesn't get bogged down with responses unnecessarily.
    Chevythunder code/troubleshooting list
    I can't vouch for those. Not factory scans, but look to be the same info in a slightly different format.
    1990 R/V truck wiring diagrams
    ALDL pinout
    ALDL cable scematics
    Ignition system test This is for TPI, but should be pretty close to TBI as well. Some of the tests I guarantee are.
    Identifying TPI system differences
    Vehicle repair guides Check these out for wiring diagrams, etc. Can't vouch for how good the quality is, but I see that our trucks are listed.
    TBI
    O2 Open circuit
    Codes 15/23/32 CTS coolant temp low/MAT sensor low temp/EGR
    Code 24 VSS
    Code 42 EST
    Code 43 EST
    TPI
    MAF wiring diagram
    MAP interior harness connector pinout
    Codes 15/45 coolant temp/O2 sensor 2.8L port
    Code 23 Inlet Air Temp (IAT) low temp indicated
    Code 24 VSS
    Code 32 EGR
    Codes 33/36 MAF gm/sec high and MAF burnoff
    Code 34 MAF gm/sec low
    Code 41 Cylinder Select Error
    Code 42 EST
    Code 44 O2 lean
    Code 54 Fuel pump circuit low voltage
    CCC
    Code 23 M/C Solenoid volts low to ECM
    Code 24 VSS
    Code 32 Baro sensor
    Injection specific:
    crank no run 1
    crank no run 2
    External coil, pickup testing
    MAP voltage/baro/vacuum chart
    C100 (fuse panel) connector '85/89 Camaro
    I also have the entire GM TBI/TPI troubleshooting sections, '89 Camaro, in .pdf (about 2MB each) if someone is interested in hosting those somewhere that I can point people to, PM if so. The TBI Camaro stuff is identical to truck in almost every regard.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Good work fella. Interesting info source for the future :waytogo:
  3. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    I am trying to install a 1987 z28 TPI onto my 1985 K5. Has anyone on here done this? I am trying to find instructions on it. I have the intake, entire wireing harness from engine compartment, computer, sensors.
    What can I eliminate from the stock harness?
    Do I need the harness from inside the car?
    Is there a book thats any good on this?
  4. dyeager535
    26,976
    Since I can't PM you:
    Please delete your post in this thread, and create a new one with a title reflecting your goal. I (and others I'm sure) will be happy to post my experiences/opinions installing '87/88 TPI into my '86. Of course, search will answer a lot of specifics as well, a few of us have done the TPI conversion.
  5. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    very nice!
