TPI Throttle bracket?
Discussion in 'The Garage' started by LKJR, Sep 11, 2005.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    hey tpi guys,
    the bracket on the drivers side of the plenum I have, (bought one since I couldn't find mine, and finally found mine, both are the same) places my cable about .75" too far back. The pics I've seen on here the bracket is opposite of mine.[​IMG]
    so did ya'll modify your bracket and reverse it or am I missing something?
    thinking maybe I need this one
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    I used the stock one on my TPI -- I'll snap you a pic this afternoon while, ironically enough, I am fiddling with the throttle bracket on my 89's TBI, lol
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The one on my TPI engine appears to mount the opposite of the one in that HUGE pic. Do you have a shot from the side?
    Anyway, mine of from an '87 Corvette. Perhaps they were different for other vehicles and/or years? :confused:
  4. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Mine mounts the same as the one in your pic
    Here it is it mounts the same as yours but mine is off while I wait for the intake RTV to dry before reinstalling it all AGAIN...lol
  5. dyeager535
    26,976
    Mines the same as the one in the huge pic. Must be an F-body vs. Corvette difference.
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    hmmm interesting thought. mine is supposed to both be off a fbody.
    I'll get a pic tommorrow.
  7. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Which cable are you using...
  8. dyeager535
    26,976
    In my case I'm using the stock f-body cable for I *believe* it's an '88. Whatever fits the throttle linkage at the TB. It's the "barrel" style. It's WAY too long for the truck application, but it works fine. It would easily run over or behind the engine and hook up on the passenger side if necessary, as far as I can tell.
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    it's a cable off a camaro. it is long and it loops between the firewall and bracket.
    the difference appears to be a bracket that has the flange closer to the firewall vs closer to the radiator
