TPI............. what blocks does it fit?
Discussion in 'The Garage' started by uglychevyZZ4, Apr 20, 2004.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    does TPI fit the older non TBI blocks since it was around in late 84? or was that the beginning of the new blocks? I am not sure if i should buy a complete TPI engine or just the tpi stuff..
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Engines the same.. it's the heads that are different.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It will fit any small block that doesn't have Vortec heads. You can buy a special manifold base that will make it fit Vortec heads, but the base costs BIG bucks. /forums/images/graemlins/frown.gif You have to do some machine work on the stock intake to make it fit pre-EFI heads. The angle on the 4 inner bolts is different between carb heads (used up until '86) and EFI heads ('87-'94 (or was it '95?), then the Vortec heads came out.
    If you want to run it on a 350, be sure to get a TPI from a 350. The 305's have smaller injectors and a new set of injectors can run ya $200-400. /forums/images/graemlins/yikes.gif
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    If you find an 88-92 TPI setup you'll have to have a machine shop modify the 4 middle bolt holes in the manifold.
    I found an '88 tpi setup, and got ahold of an '86 manifold so it will fit my pre '87 heads. /forums/images/graemlins/thumb.gif
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep to get TPI to fit pre 87 motors you have to bore out those 4 bolt holes or find a TPI manifold from an 85 or 86 year motor. I bored out the 4 holes to make mine fit. It is a PITA and if I had to do it over I would take it down to the machine shop and have them do it. It shouldn't cost that much.
    Harley
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Hossbaby50
    How's your running now that you've had it in for a while...
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It has been running good for the most part. The only problem I have been having is it keeps killing ignition parts. A month ago I toasted a pickup coil, then a week after that a module. Yesterday I toasted something too. Haven't had time to figure it out yet though. /forums/images/graemlins/dunno.gif Once the ignition thing is ok it will be great. I am going to rip into it this afternoon.
    Harley
