TPI wiring harness
Discussion in 'The Injection Section' started by 85 Jimmy, Feb 11, 2007.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    ok guys, i have a complete setup from a 86 camaro, as you know that used MAF. I'm swapping to speed density and have an ecm from a 91 corvette. is there anyway i can modify the harness from the 86 to work with the 91 corvette ecm and everything else that comes with the speed density swap?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yea you can modify it, you will need to get the correct computer plugs and you will need to get a Map sensor and plug, then using ECM pin outs re pin the conectors to match the new computer and add the nessary wires to the harness and delet the ones not used (MAF)
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    I did the same with my truck -- It isn't half bad so long as you can get an ECM that already has the correct memcal in it and comes with the plugs, and have wiring diagrams for both ECMs.
  4. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    could you give me the diagrams please?
    when i got my ecm they cut the wires about 6" back so i have that much wire and the connectors
  5. dyeager535
    26,980
    Head over to thirdgen.org. I believe it's one of the tech articles. (not in the forums) You could probably find a link to that article as well by searching the forums of course too.
    1227165 1227730 wiring swap would probably net you the article there.
    Ah heck, here it is :): http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
  6. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the only thing is if you have a ECm form a vette it will be different, they were weather pack computers that went under the hood so there are 4 connectors and the pin outs are different than the 730, i belive you have a 727
  7. Russell
    Jun 23, 2000
    7,924
    336
    www.chevythunder.com also has wiring diagrams for the `165, `730, and `727. I got all the diagrams I used there :)
  8. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    pardon my ignorance but why do you not want to use the MAF system?
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Mostly because the early TPI MAF systems were made by Bosch, using a quite fragile hot wire. Replacement MAF's are stupid expensive. :yikes:
  10. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    not to mention that MAF systems do not like vibrations anf dirt, not like we see any of that stuff:D
  11. dyeager535
    26,980
    I gotta disagree with the dirt/durability issue.
    Regardless if car or truck, over their lifetime the MAF's see amazing amounts of vibration and potential dust. I've got two stock Bosch MAF sensors from the 80's (of course) that still work, and both are off of, or currently used in a truck application.
    IMO MAF durability is not something to be concerned about. COST is what you need to be worried about. They've gotten away from the wire MAF's from what I can tell, the aftermarket Microtek or whatever they are use the thin film setup, which means no wire. They are still over $150 last I heard, it makes more sense to swap to MAP when your MAF fails than to buy another MAF sensor. Again last I checked, MAP's could be had for $50.
    I've cleaned my MAF wire with a q-tip and alcohol, the wire isn't THAT fragile, unless you are a gorilla. :)
  12. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    yeah, the computer i have is the 1227727.
    the reason i am going speed density is b/c i want to run a filter right off the front, istead of a elbow and MAF sensor and then a filter.
  13. dyeager535
    26,980
    Routing is of course another issue, MAF certainly loses on that one as well.
    I assume you are going electric fans with this setup, I don't believe a filter off the TB will clear the stock clutch fan.
  14. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    yep, already have a 2 speed taurus fan in
