TPS adapter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Jan 17, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Is there a company out there that makes an adapter to hook up flat style to round TPS?
    AW
  2. dyeager535
    26,982
    191
    If this is just a shape of the plug issue (and not different # of wires) why not just go get the right plug and re-pin it?
    I have a friend that can get GM connectors if you want his email address.
  3. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    how about the temp sender pigtail? not the cst but the one for the temp gage. need the male end that plugs into the sender.
    jason
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you are referring to an adapter that will allow a BBC TPS switch to be used with a SBC wiring then yes, there is such an adapter available. Try TurboCity.com
  5. jmd
    jmd Registered Member
    Oct 25, 2001
    63
    Phoenix, Aridzona
  6. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    i think so. mine was missing when i got the rig so i'm not sure. looks like it would work /forums/images/graemlins/tongue.gif
