TPS not bad, check engine light still coming on...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Apr 6, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My check engein light will still come on randomly, always at highway speeds. I have replaced the Oxygen Sensor and borrowed a TPS off a 90 PU that doesn't have this problem, and it still happens, and my TPS is fine on the other truck...any ideas what could be wrong with it?
    BTW, is it possible this is because of my Hypertech Thermomaster chip? I am supposed to run Premium, but always run regular. I have heard this will make the computer retard the timing, so I think I will take it back to stock...hopefully that will help...any more ideas?
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Run premium and see what code is in the computer. Throwing random parts at it will not turn the light off.
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Have you looked into WinALDL yet? it's a freeware program that will allow you to connect a computer to your ECM and see what's going on with the light.
    Check it out <a target="_blank" href=http://srd.yahoo.com/goo/winALDL/1/T=1018203632/F=fa66752e0740c6cad7d50831e583cea5/*http://w1.601.telia.com/~u60113744/software/winaldl/winaldl.htm>WinALDL Home Page</a>
    I use it to diagnose my '92 TBI Camaro, and it has been invaluable.
    Good luck,
    Thomas.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I put the stock chip back in, and disconnected the battery for a while and it still does it. I may try that FreeWin program...where can I get it?
  5. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    If the light comes on at highway speeds i can guarantee that it is your egr valve or something to do with the egr valve whether its a bad sensor or the valve itself, if you know how to do flash codes with the Service engine soon light, the egr code is code 32.
    Justin
  6. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Just click the link in my previous post to go to the WinALDL home page. You'll need to make an interface cable to use it. The parts cost about $10 from radio shack, and there are directions on the web page.
    Thomas.
  7. jmd
    jmd Registered Member
    Oct 25, 2001
    63
    Phoenix, Aridzona
    What code is it setting??? That's all you need to effectively track it down. EGR is usually highwayish though. Cleaning the passages or replacing the solenoid are things to look into *if* it sets an EGR code.
    I am ordering a cable for winaldl this week. I already have a scanner that does 99% of GM / Mopar/ FoMoCo but I have a laptop and want to try winaldl on my MAF TPI and my CCC and a friends SD TPI.
    The guy I contacted on the cables he sells will make me one where the 10k resistor is switchable so I can use it on the SD and the MAF....
    Matthew
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Link the ALDLpins and do the cheap man's scanner and find out what code it is setting instead of chasing a bunch of could be's and might be's. I do agree it sounds a lot like an EGR. I would take it off and clean it out real good. Make sure it works and the plunger moves and reinstall.
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The light goes off as soon as I turn off the ignition, so everytime I try to check the codes I get nothing.
  10. Stock88Jimmy
    Stock88Jimmy Newbie
    Apr 9, 2002
    This may or may not help, but I get a Check Engine light usually at sustained highway speed. I ran the code and looked it up on ALLDATA and it said that the code may occur when the exhaust has been modified.
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I wonder how modified it has to be for that? I have a Flowmaster and a Catco cat on mine....
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Took it out on the freeway and drove it hard, and the light didn't come on, hopefully cleaning the EGR Valve helped it.
  13. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    get a carb set up. then when smog time comes up put it all back on and go.
    grant
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Its actually about smog time now, and I have no desire to have a carb....i think its fixed anyway.
  15. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    Was it the EGR because I've had the same prob. for awhile and have been just ignoring it.
