TPS/Transmission shift problems...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Piranha300, Jan 3, 2004.
  1. Piranha300
    Piranha300 Registered Member
    Jul 1, 2001
    45
    Nebraska
    For some reason my TPS needs reset (disconnect the battery) in order for my transmission to shift gears. This has happened twice after a long trip on the interstate (300 miles) Anyone know why I would need to reset the TPS to get it to shift?
    All of this started after I replaced my original TPS (check engine light came on... code-TPS set too low). My new one is nonadjustable just like the original.
    Any info would be greatly apprediated! Thanks
    I have a 91 K5...
  2. k5moneypit
    k5moneypit Registered Member
    Jan 6, 2004
    18
    brownstown,michigan
    I have an 87 k5 , when i had shifting problems I checked the dealership for a prom update and sure enough that was the problem. Also TPS while not adjustable, just the slightest tilt while screwing it down can alter it. Although I dont think its your problem, something maybe to do with your shift cable,that is also hooked to tbi.Something to look into. Hope that was some help.
  3. Piranha300
    Jul 1, 2001
    45
    Nebraska
    How do I get the prom update? New computer? Thanks
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    new prom, check the dealer, should be around $45-50
