TPS voltage tuning
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burbinator, Nov 5, 2001.
  1. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    When I used to race EFI Mustangs years ago for a hobby, one little tweak we used to do was dial in the TPS sensor voltage at idle to about .90 - 1.0 VDC. Is there a similar tweak on the TBI? If so, what is the optimum voltage (idle) and which wire should the reading be taken from?
    Thanks in advance!
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>U.S.S. Nimitz II</a>
  2. tlarsw
    tlarsw 1/2 ton status
    Jan 12, 2001
    270
    Cameron, NC
    TPS voltage should be &lt;1.25 volts on the GM TBI.
    The three wires are (I'm color blind) black, grey and blue (I think)
    I think it's the grey and blue wires. You can make a jumper wire (NAPA has all the right connectors) and leave an offest bare spot on each wire. Check between two wires, If you get a reading of 5 volts, this is the reference wire. You'll check between the other two wires.
    1986 K10 TPI350/NV4500/Gen2 Doubler/D60(ARB)/14FF(Detroit)/4.56 gears
  3. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    There should be a reference voltage (+5VDC), ground and the output voltage used by the computer. Sounds like the grey would be the output, blue for the reference and black for the ground.
    "&lt; 1.25 VDC" is good for verifying a good part, but there should be an "optimum", similar to the Mustang 5.0
  4. tlarsw
    Jan 12, 2001
    270
    Cameron, NC
    That is correct on the TPI. (.52 +/- .075 VDC)
    I just set up a TBI this weekend using the GM fuel injection manual.
    For the TBI, it only stated that it had to be &lt; 1.25.
    I figured it's because the TBI doesn't have the performance characteristics of the TPI or 5.0 injection system.
  5. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Thanks for the info, but I'm not interested in what the manual says.
    I'm looking for the "field tweak". True, it doesn't have the performance characteristics of the other systems, but there should be a voltage that works better than most.
    The F*rd 5.0L manual said "&lt; 1.2 VDC", .90 VDC was optimal...see my point?
    <a target="_blank" href=http://photos.yahoo.com/abshort1>U.S.S. Nimitz II</a><P ID="edit"><FONT class="small">Edited by Burbinator on 11/05/01 03:37 PM.</FONT></P>
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    With a TBI you get better results tweaking the MAP sensor than the TPS.
    Summit sels some boxes for the TPS that will take care of the bog you somtimes get with a TBI
    But go to :http://coloradok5.com/gallery/Thunders-Blaze
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  7. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Now that's what I'm talking about!
    I knew there had to be SOMETHING to improve it...
    Thanks!
  8. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Not quite what you asked for but if you put a 640 ohm resistor across the coolant sensor the computer will think the engine isnt warmed up and give you more advance and hence power...
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  9. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Remove TPS...hog out mounting holes...adjust to about .075V with scanner. Have scanner in the garage...can help you out some weekend.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
  10. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    I might take you up on that offer...thanks!
