TPS Voltage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Jan 26, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    I need to adjust the voltage to my throttle positioning sensor, i just have no idea how. any ideas /forums/images/graemlins/k5.gif
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Do you have a voltmeter? The TPS (ThrottlePositionSensor) has 3 wires going to it, one wire will have no voltage present, it is the ground for the sensor from the ECM, a second wire will have a constant voltage (approx. 5 Volts) this is the ref. voltage for the sensor. The third wire should have a voltage that varies with the movement of the throttle shaft, That is the voltage you will adjust. Hook up the meter to monitor that voltage, "loosen" the screws holding the TPS to the throttle body, the screw holes should be slotted to allow for adjustment, you will need a voltage setting from a shop manual for your system, move the TPS to obtain that voltage on your meter(probably at idle) and tighten the screws. The ignition key should be on with the engine not running when you get your readings and make your adjustment.
