Track bars or Sway bars?
Discussion in 'The Garage' started by slicer4559, May 22, 2006.
  1. slicer4559
    slicer4559 Registered Member
    Mar 16, 2006
    14
    Oregon
    Hi all, I have a 79 GMC Jimmy, with a 10inch suspension lift and 3inch body lift, the axles have 4.56 gears and running on 38inch mickey thompson baja ATZ's, I was thinking about building and putting on trackbars, but by the time I got it all fabbed up and mounted I'd lose to much clearance between the springs and frame rails, so I'm thinking about using a good stout anti sway bar instead to eliminate more of the tracking and swaying i have. Anyone here have any input on the matter, or maybe a decent set of plans on making and mounting trackbars so i keep all my clearances?. Anything will be appreciated. email me if it makes it easier. b_keller46@yahoo.com. Thanks
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Welcome to ck5. What are you trying to build this truck to do?
  3. slicer4559
    Mar 16, 2006
    14
    Oregon
    Its mostly an on road rig, 85% asphault, 15% offroad, so i'm tryin to get the wandering out of it, the new tires took care of 90% of it. so i got to get rid of most of the rest of it, so the wife dont freak!, when she drives it....lol.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    have you had it aligned since the lift?
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    With that much lift, I would think the springs would control sway motion fairly well. For me the sway bar took too much flex away, and with 4" springs it drives well enough without a sway bar.
  6. slicer4559
    Mar 16, 2006
    14
    Oregon
    no, i havent, but i'm guessin, that to get it to come out right, you'd have to have the knuckle pivots cut off and rotated back into postion, i have 6degree shims in the front, and rear to help the drivelines out. it seems when on a good street, it drives just fine, but when you get on a well worn road is when i have the problems.
  7. slicer4559
    Mar 16, 2006
    14
    Oregon
    hi mouse, even though the front springs have poly bushings, theres like almost half an inchof poly sticking out each side , so even though there new, and 10inches of lift, you'll still get a fair amount of flex.
