Traction bar mounts
Discussion in 'OffRoad Design' started by TWISTEDJACK, Apr 12, 2005.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Can you cut the axle radius higher so the bottom link could double as a little drive shaft protection? I know you put a great deal of R & D into your products so I know there has to be a reason. What are your thoughts on this?
    kevin
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Are you Talking about the Four link brackets?
    I am confused.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The idea with the higher pivot point was to keep the ground clearance. I didn't look at the driveshaft so much since you're going to be 10" or so away from it. With a longbed truck on a really flat ledge it might help you out to have that bar a little below the driveshaft though. With these brackets you'd have to put a little bit of a belly in the bottom tube to drop it down below the driveshaft. I guess this also depends on the pinion angle you're running compared to the bar angle.
