Traction Bar Question?!?
Discussion in 'The Garage' started by OffRoader93, Jul 18, 2005.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    Can the traction bar be welded to the axle or does it have to be a heim joint. Any help would be great. Thanks.
    Brenton
  2. OffRoader93
    Nov 30, 2002
    262
    Anyone have any ideas? Thanks.
    Brenton
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Would be a good idea to be able to unbolt it from the axle housing, but whether it needs an SRE depends on which design traction bar you go with.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    ORD sells a weld on kit to mount a traction bar. I would NOT weld the bar to the axle. You can use these poly bushings instead of heim joints.
    Here's the information from ORD's site:
    This kit is the axle end of a single ladder style traction bar ready for a do it yourself fabricator. The plates are laser cut 1/4" with 9/16" holes on 8" centers. The bushing assemblies are our BA175 and BA175HD (heavy wall HD outer tube for the bottom mount). The axle radius is 3 3/8" for the GM 14FF rear axle and can be easily modified for larger tubes. A 3" tube version is also available for most 1/2T axles. These mounting plates are also ideal for a link suspension.
    #U8050 - pair of plates only for 3" radius axle tube - $25.00
    #U8051 - pair of plates only for 3.375" radius axle tube - $25.00
    #U8052 - Traction bar axle mount kit, includes plates and bushing assemblies for 3" tube: $46.00
    #U8052 - Traction bar axle mount kit, includes plates and bushing assemblies for 3.375" tube: $46.00
    Link to the page.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Me thinks its time for ORD to update their front page, I didn't know they had a page with those bushings or those brackets made up. Good to know, need to order some bushings for my upper shackle bushing in my front.
  6. OffRoader93
    Nov 30, 2002
    262
    i need help!!
    thank you !
  7. blownout
    blownout Registered Member
    Jul 19, 2005
    18
    ont.canada
    i can help u
    i will drive to u and help u out if u pay me ?
    sound good to u email me . thnk u bill ont.
  8. blownout
    Jul 19, 2005
    18
    ont.canada
    cool
    cool i'll drive my bronco down this week thanks for the map to your house this will be cool i love the usa u all litter all over the roads and your homes are reel big . bill ont. :bow:
  9. blownout
    Jul 19, 2005
    18
    ont.canada
    i see u
    hey i i got all blown out to day but im on my way man see u in a few days your bud bill .
