Traction Bars For '73-'91 Blazers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ford_assassin, Dec 3, 2003.
  1. ford_assassin
    ford_assassin 1/2 ton status
    Nov 8, 2003
    101
    Bakersfield, Ca.
    Traction Bars For \'73-\'91 Blazers?
    I am looking for ways to improve the traction on my '86 Blazer. On a car I with rear leaf springs I would just buy a pair of traction bars or "slapper bars" as some call them.
    More or less they help with wheel hop and excessive pinion angle.
    So, does anyone know where to find some traction bars for my Blazer? A part number and company would be great!!
    Thanks guys!!!
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Traction Bars For \'73-\'91 Blazers?
    i believe echobit fab sells a nice v-bar traction bar setup that doesnt limit wheel travel..
  3. ford_assassin
    Nov 8, 2003
    101
    Bakersfield, Ca.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You could try the rancho kicker shocks that bolt to the top of the u-bolts and to the front of the fenderwell horizontaly. They are supposed to help a little besides they are probably enough for our trucks unless you have some crazy HP and it's hopping like mad. There is also solid bars available instead of a stiff shock.
  5. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    I have been thinking about those myself. Do you think they work? the price isnt bad at all.
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    IMO they are crapola....
  7. Confedneck
    Nov 1, 2002
    5,236
    i thought it was echobit selling the sliding v-bar traction bar?? try a search of the forums and you should find it..or PM borregok5 and ask..
  8. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
  9. ford_assassin
    Nov 8, 2003
    101
    Bakersfield, Ca.
    www.mo-offroad.com
    Hmmmm, what I am I missing? I don't see anything on that link-page that has a traction bar listed.
    Thanks though.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Just wondering why you want Traction bars on a stock Blazer?
    Unless you are having bad axle wrap problems. (which can be cured with better springs)They are a waste of money in my opinion. They hang down too far, get hung up on rocks brush, Stiffen up the flex too much, ect They might help a bit in hill climbing.
    BUT
    If its traction you are after, your money would be way better spent on a locker or posi unit.
  11. ford_assassin
    Nov 8, 2003
    101
    Bakersfield, Ca.
    BUT
    I already have a locker in the rear, posi in the front.
    Oh, my engine current engine is stock. My new 383 stroker with ported '70's LT-1 heads isn't. It dyno'd somewhere around 450 Ft lbs of torque @3800 RPM. My " HD Towing" converter flashes at 2000 RPM right now. It shouldn't have any problem smoking all 4 tires in 4H with ease. Especially when I get too excited when leaving from /forums/images/graemlins/thumb.gifa light (or a Honda) in hurry.
  12. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Its a 383 stroker with Pro Topline heads, somewhere around 450 Ft lbs of torque. It smokes all 4 tires in 4H with ease
    doh!!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  13. Confedneck
    Nov 1, 2002
    5,236
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Oh, my engine isn't stock. Its a 383 stroker with Pro Topline heads, somewhere around 450 Ft lbs of torque. My " HD Towing" converter flashes at 2000 RPM. It smokes all 4 tires in 4H with ease, normally when I get too excited when leaving a light (or a Honda) in hurry.
    Not bad, it's a little harder with boggers though.
  15. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
  16. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    ORD
    j
  17. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    www.mo-offroad.com
    Thanks though.
    Go to the What's New or new product page and there you go.
  18. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Hmmm your rig is far from stock /forums/images/graemlins/rotfl.gif I was responding to your sig.
    Maby trac bars would help a little /forums/images/graemlins/smile.gif
    If you cant find any
    Rancho makes trac bars.I think they call them Torque Rods or something like that. They dont list for a Blazer but they fit short bed half ton GM PUs and I am sure they can be made to fit a K5.
  19. ford_assassin
    Nov 8, 2003
    101
    Bakersfield, Ca.
    I doubt it would be an issue either, as long as the gears are at least 4.11 or 4.56. I don't plan on getting crazy with more lift or tires, so I guess I'll never know.
    I don't normally brag about the motor because the last time I did that with a ride it was stolen, stripped, and burned. I try to keep the "low profile" thing now.
  20. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    before I lifted my blazer I had a traction bar fom JC Whitney (dessert steel is the company name). Its an over the leaf type traction bar and it has a threaded rod that bolts to a plate that bolts to the front shackle mount. IT DOES WORK. I dont think it would work for lifted vehicles and it does probley limit travel. I never had any problems using them with stock leafs though.
