traction bars
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by highrider_44s, Mar 28, 2004.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    I was looking at building a set of traction bars for my 81 chev truck it has a 4" shackle flip and a 6"block in the back. was wandering what would be the best design option. one that doesn't affect articulation or ground clearence that much any onfo would be rock thax
  2. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Ummm, people who look in here also look in that garage most of the time /forums/images/graemlins/waytogo.gif
    Double Post
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    A flip creates some axle wrap.... 6 inch blocks really create axle wrap, So i understand your need for a traction bar. However, i think it might be a better idea to put some of that time/money/or energy into getting rid of that tall block. It would really reduce the axle wrap. Try a set of 6 inch leaf springs.
    But if you are still going fot a traction bar...I believe that you need to create a mount that is lower than the axle centerline. Also, the longer the bar, the better. (helps with articulation with a longer bar.)
    But there are other schools of thought on this...such as the anti-wrap bar by Az-Kickin
    Blake
