traction bars
Discussion in 'The Garage' started by ok91blazer, Jul 12, 2002.
  1. ok91blazer
    ok91blazer Registered Member
    Jul 7, 2002
    42
    stillwater, ok
    hi, i have a 4 in, sus. lift for my 91, and i was told that i should get soem traction bars, but dont they cut down on ground clearance kinda liek get hung up on alot of things, and does ORD make them, or how hard would it be to fabricate mine own, if i was to make my own, what do i need to look for and what type of metal tubing should i use, and id like to hear from other peoples pro's and con's against and for them to help make my decision. I'm gonna run 35 12.50's under it if that makes a diff.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Why do you need traction bars? If you dont have huge amounts of wheel hop on the back end, spend your money on the tires.
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Hello fellow Okie!! I just finished a 4" lift on my '86 K5, and no, you don't/won't need any traction bars. If you were pushing a 500-600 hp K5 dragster maybe. /forums/images/icons/shocked.gif /forums/images/icons/grin.gif
    Hollar if you need some help, I'm in OKC.
    John
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    im runnin about 1200 blown nitrous ponies and a 12" lift, and at times i do hafta have traction bars when racing, but like everyone else said, there is no way in hell u should need em for ur setup. good luck
    NITRO
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    If you get into some really flexy springs like the F150 ones and set up for a lot of travel, you could benifit from a single ladder bar which runs to a shackle mounted accross from the front spring hanger. It helps eliminate axle wrap and doesn't inhibit flex. Take a search through some posts, there was a pic of one here just this week.
  6. ok91blazer
    Jul 7, 2002
    42
    stillwater, ok
    its always nice to okie boys on here, yea, after i get all my stuff together were gonna have to hit up soem trails.
  7. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Michael,
    Is this what you are talking about?
    James
  8. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've seen those but haven't heard any reviews on them yet. I can't find the thread but I found the image in my computers cache so here it is. [​IMG]
  9. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    But you have my curiosity, how do you like it? Drawbacks?
  10. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    They were on the truck when I got it so I'm not really sure how I like it since I've only driven it one way. It feels like my axle is loading up when I try to "get on it" from a stop. I have 2.5" blocks so I'm sure that has a lot to do with it. The only drawbacks I can see is the front shackle mount. There doesn't seem to be much give there. It will do this though. I don't know about how much travel they would cost on suspensions with LOTS of flex.
    James
  11. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    How is the bar attatched to the plate bolted at the front spring hanger... radius arm, ball pivot???
  12. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    I don't know what the mount is called but here is a few pics.
    This view is from the front. [​IMG]
    This view is from the back. [​IMG]
    If you could figure out how to put a Joint like the front has on that yellow bar I think you could get more flex out of them.
    James
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Ah, its a radius bushing. I think I'd stick with the shackle on the ladder bar setup for better droop because your fixed mounted to the axle leaving no place for axle wrap to sneak back in. In your case where you have rotational capabilities at the axle its a better option but I can see where it wouldn't fully combat the wrap up, but would inhibit it! I've seen a setup similar to yours where the bar has been repalced with a shock absorber... another interesting twist on the idea.
