traction device advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rebel88, Jul 6, 2002.
  1. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    ok heres the deal...getting ready to replace gears in my 10 bolt up front...
    14 bolt rear has a detroit in it with 4.88s
    wanna go with something up front, possibly a locker but most likely a limited slip, but i wanna take it easy on the 10 bolt...
    thanks for any and all advice
    Later
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Get the Detroit Truetrac so you can steer the damn thing. /forums/images/icons/wink.gif
  3. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    anybody else have any input?
    Later
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    The new eaton limited slip is one fine piece of machinery. I would even get one in the rear it works so nicely. ALmost no LSD chatter. Rebuildable, adjustable, you name it. Ohh and it also replaces something in the rearend... or front end in your case (literally) that is supposed to add strength and make it as strong as a 12bolt. So i've heard and read. Too bad i went with a powertrax lockrite and blew that bad boy out 2 weeks later /forums/images/icons/crazy.gif So, word of advice: If you have manual tranny, try taking it easy and not dumping the clutch /forums/images/icons/grin.gif
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Grow a set and lock it up. It's not any harder on the front end to have even torque to both shafts all the time than it is to have one wheel spinning like crazy and then hook up suddenly.
    And I have no steering problems with my front Lock Right. No open diffs or LSD's for me! /forums/images/icons/cool.gif
  6. RedDwarf
    May 9, 2001
    816
    incidentally, I have been running these units for a long time with 35-38" tires. I have broken the axle shafts numerous times but no damage to the Lock Rights as of yet (knock on wood)
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Can you say...."time to upgrade to ORD shafts and CTM u-joints?" /forums/images/icons/shocked.gif /forums/images/icons/wink.gif /forums/images/icons/grin.gif
  8. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Then you'd start breaking ring gears instead. Ask Shaggy about that.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    LMAO!! So I've heard! /forums/images/icons/laugh.gif /forums/images/icons/grin.gif
  10. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I think i broke the shear pins for the lock right
  11. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    planning to go with the new shafts too...
    just wondering on what traction device i should go with...im thinking of the detroit and since it is sometimes used for long hauls to the beach(not a trailer queen, it gets driven down and back) it needs to be streetable...
    Later
  12. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Unlock the hubs and you won't have to worry about the street.
  13. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I have a detroit in the front and i love it. Sometimes steering is a little squirly if im going fast but on the trail its hardly notcble but if i gass it really hard it tends to get going and not really want to turn.
    On the street with the hubs unlocked its not an issue
  14. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    am i looking at mucho damage with just a 10 bolt and a detroit or should i be ok with a normal persons amount of right foot and some chromoly shafts?
    Later
  15. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Got the detroit in my rear 10b, no problems yet, its been there almost 18 months /forums/images/icons/laugh.gif I do have the hardened shafts in there though. If you go into the ice, you will not like a locker at all, if you just play in the mud, sand, snow, and rocks it works great.
  16. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    yep got the detroit in my 14b in the rear...worked great in sand and mud...not much snow here in VA so im not worried about that
    Later
  17. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    one more thing...where did you get the hardened shafts and how much did they cost you?
    what tires/gears you running?
    Later
  18. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    4 wheel parts wholesalers, check their website
    www.4wheelparts.com or Randy's Ring and Pinion www.ring-pinioin.com
    Mine were $129 a piece for the rear, but it is a 10b. As for front long side and short side will be different. Good Luck.
